  • Guests: 51
buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
SCR supplier in australia?
ZapHappyPrimate
Thu Oct 01 2009, 03:01PM Print
ZapHappyPrimate Registered Member #2393 Joined: Sun Sept 27 2009, 07:36AM
Am wanting to use an SCR for triggering my CG.
Jacar's best is only 88A peak current, at ~$5 a piece. (just not good enough....)
Farnell's best is rated at 800A peak current, at ~$15 a piece.
Are there any other good sources for SCR's in oz?
PYLEMET-mk2
Thu Oct 01 2009, 03:48PM
PYLEMET-mk2 Registered Member #1513 Joined: Sat May 31 2008, 12:08PM
800A peak current is enough
Bonehead
Thu Oct 01 2009, 05:24PM
Bonehead Registered Member #2046 Joined: Sun Mar 22 2009, 01:12PM
You should calculate voltage of the caps and total circuit resistance to get an idea of your peak current, or better yet use Barrys simulators
Inductor: Link2
RLC: Link2
That'll give you an estimation of your peak current which will give you an idea if the 800A peak would be enough.
Farnells price seems quite good for a 800A peak too.
Don't know of any suppliers though, sorry.
rp181
Thu Oct 01 2009, 10:16PM
How can you say that? He did not give specs.
Keep in mind peak current is for 10ms or 8.3ms, coilgun pulses will be much shorter, and pulse current ratings go up exponentially.
PYLEMET-mk2
Fri Oct 02 2009, 03:50AM
wrote ...
800a peak is enough for caps up to 500j (400-450v) and coil about 100-300mkHn - I think that newbie user wouldn't have more caps.
ZapHappyPrimate
Fri Oct 02 2009, 10:05AM
yes, 800A is enough, only using ~70j. My question was more about finding more than one source for parts. As it is, I will go with this for now, but cannot be sure they will always have stock.
