  • Guests: 33
12/25 Kolas (18)
12/26 buxtronix (50)
how to power up my capacitors effecient and quick(less then 4min)
TechNerd
Wed Sept 30 2009, 05:29PM Print
TechNerd Registered Member #2289 Joined: Thu Aug 13 2009, 02:49PM
Hi
I'm looking for most efficient way to power up the capacitors for my coilgun
capacitors: 2 x 2200uF 400v wired up in parallel so it's 4400uF 400v
my goal is to get the voltages up to about 350v or so..
Right now I'm using an uc2845 IC do make a flyback DC/DC converter from 20-200v... but it takes about 6min to power up the capacitors to 200v sad
I work as an electronics technician, and has access to just about all electrical components (parts is not a problem) cheesey
also how do I make the most efficient coil for the gun, the barrel is 16mm in diameter (got copper wire in most of the AWG types)
thank guys...
big5824
Wed Sept 30 2009, 05:48PM
You could just rectify the mains, that will output a max voltage of 340v (assuming your mains RMS is 240v like it is in the UK)
however i strongly recommend using two back to back transformers to limit the current if something goes wrong.
teravolt
Thu Oct 01 2009, 03:25AM
if you want it portable buy a 120v car inverter and with a series resistor use a capacitive dubler
PYLEMET-mk2
Thu Oct 01 2009, 05:05AM
PYLEMET-mk2 Registered Member #1513 Joined: Sat May 31 2008, 12:08PM
TechNerd, use this scheme Link2
This device maked by that scheme Link2 charges caps to 400v with 60w power - it means that your caps will be charged in 6 seconds
TechNerd
Fri Oct 02 2009, 05:52PM
Hi again...
I've changede the IC to an UC3845 *(from UCC3808) and made a new transformer coil with some bigger wires...
then I ran into a new problem, the diode between transformer and capacitor started to frie... now I'm using a MUR6040 so it should be able to handle the power...
buttom of it all now i'm able to charge the 4.4mF capacitor to 270v in about 2min...
another thing... how do I make the most effective coil
thanks guys...
Backyard Skunkworks
Fri Oct 02 2009, 07:27PM
It'll be way faster if you either use Llevellyn's idea or just go ahead and make a step up transformer from mains, unless you want it to be highly portable.
I rewound a 12v wall wart to a step up 320v autotransformer for 120v mains. Charge time is a few seconds for a bank that size and the current limiting is very good.
A good coil is roughly the same length as the projectile and will produce a very quick high current pulse. 12-16 ga is probably going to be your best bet, really you should look up barry's LCR sim and try to get it dialed in.
And 16mm is really huge, I would go for a thinner barrel, more in the range of 6-10mm
Jasonr
Wed Oct 14 2009, 11:21PM
Jasonr Registered Member #167 Joined: Mon Feb 13 2006, 06:41PM
I would do a boost converter like this.
Dr. Resonance
Sat Dec 26 2009, 05:58AM
Dr. Resonance Registered Member #1670 Joined: Mon Sept 01 2008, 08:32AM
I use a line operated power transformer. An old large TV xmfr from a large CRT type TV will work good. Can be overloaded up to 500% for short duty cycles.
It should charge all your caps in 10-15 sec (max). I run a higher voltage and use a 1,200 Erms 2 Amp xmfr to charge all 5 stages of my machine in 10 sec or less.
Dr. Resonance
