  • Guests: 35
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Voltage controlled oscillator
Frosty90
Sat Sept 26 2009, 02:17AM Print
Frosty90 Registered Member #1617 Joined: Fri Aug 01 2008, 07:31AM
Hi all,
Just throwing an idea out there. Would it be possible to implement a standard rectifier diode as a crude varactor for making a simple CMOS VCO? The reason I ask is after reading the thread on 'singing arcs', and FM modulation, I thought I might like to try that with my mini 5MHz TC. Or any other siimple VCO designs?
Cheers,
Jesse
Sat Sept 26 2009, 06:27AM
Yes, very much so.
All reverse biased diodes exhibit capacitance variable with bias.
Purpose-made varactors, however, have greater linearity and capacitance range.
You may find the following page on the use of rectifiers and LEDs as varactors/varicaps helpful:
Frosty90
Sat Sept 26 2009, 07:23AM
Thanks,
Thats exactly what i was looking for!
Cheers,
Jesse
Sat Sept 26 2009, 07:55AM
You can also use a MOSFET with its gate and source shorted as an audio input, and the drain to the timing cap input.
Like this (schematic in Paint from a friend tongue )
1253951677 152 FT76665 Modulace
(thats with the IR2153 half bridge controller, but 555 or other similar ICs will work too)
Sat Sept 26 2009, 11:33PM
Or gut some varicaps from cheap FM radios.
GeordieBoy
Sun Sept 27 2009, 01:22PM
If you are using FM to create an audio modulated tesla coil, I think the distortion from a slightly non-linear varicap diode will probably be swamped by that caused by other mechanisms!
-Richie,
