  • Guests: 51
Singing arc failure
Fri Sept 25 2009, 05:32PM Print
I have set up an FM singing arc like this: audio in > op-amp (gain ~20) > 4046 VCO 25-100kHz > gate drivers > GDT > halfbridge > rectified TV transformer.
Everything checked OK (gate waveforms etc.) so I turned it on and got an arc. I started increasing the volume when suddenly the bridge popped.
I have ABSOLUTELY NO idea how that could have happened. The VCO has ultimately limited its frequency above 25kHz so the bridge cannot pop because of overcurrent. The supply voltage for the halfbridge was 330V DC and 50 turns on the transformer primary, which is more than enough even for 25kHz.
Does anyone have an idea what happened? I can't see anything wrong with the circuit, don't want to put another set of FETs in and pop them again.
Fri Sept 25 2009, 05:40PM
The rectified flyback sticks out as a problem to me. I suspect it saturated because of the single rectifying diode.
Fri Sept 25 2009, 05:47PM
Uzzors wrote ...
I have driven these xformers without problems from a bridge. Like I said, I turned it on and got an arc, turned it off after a while to check the FETs and they were cold. So I turned it back on and started bringing the volume up from zero and then it popped.
Fri Sept 25 2009, 06:03PM
I would probably repair the bridge and use a mains filament lamp as a light load,
'scope the output whilst increasing the audio modulation.
You may see the problem on the 'scope,
at least you'll have eliminated the bridge/driver as the source of the problem.
Fri Sept 25 2009, 06:32PM
Sulaiman wrote ...
I might try that, but I'm afraid I'd see just blurry trails on the scope because of the frequency modulation... (I have scoped the output of the gate drivers while inputting the audio, and you can't really see a thing on the scope).
GeordieBoy
Fri Sept 25 2009, 07:38PM
If you increased the FM depth too far the VCO may have actually stopped oscillating at the troughs of the audio waveform.
Keeping one MOSFET on for too long in the half-bridge is goind to cause the magnetising current on the LOPT to ramp up to dangerous levels if you haven't got a DC blocking cap in there. Did you use a DC blocking capacitor, or just tie the load between the bridge leg and the mid-point of a bank of electrolytics?
That would be my guess at what is happening. A similar thing can happen in TV horizontal deflection circuits. If you keep the HOT on for a fraction too long, the LOPT core can saturate and the transistor dies instantly from overcurrent.
-Richie,
PS. Also bare in mind that applying rapid and deep frequency modulation can upset the nice 50% duty ratio you get out of the VCO. This in turn upsets the volt-second ballance across your GDT, which can affect how hard each of the two MOSFETs are getting turned on. Instantaneous deviations of the half-bridge's duty ratio from 50% could also cause the mid-point of the capacitive divider to shift in voltage too. If the capacitive divider voltage doesn't shift quickly enough, then a net DC bias across the LOPT primary is likely to saturate it fairly quickly.
Fri Sept 25 2009, 07:51PM
GeordieBoy wrote ...
Prior to firing the circuit up, I have tested the input of the VCO with a potentiometer ("outer" pins to supply rails, wiper to VCO input), and it seemed to work well from 0V all the way up to Vdd (frequency tested on scope).
You are right, I haven't used that cap. But that was because I thought the frequency can never drop below the VCO minimum.
I thought about this too, after all it seems like the only possible explanation.
Thanks for the help
GeordieBoy
Fri Sept 25 2009, 08:12PM
> Thanks for the help
No worries. Problems like this can be quite frustrating to diagnose.
SMPSU designers have to be careful in things like full-bridges and push-pull converters. Any rapid modulations of the duty-ratio can cause unequal conduction times for the two pairs of switches. This causes a temporary imbalance in the volt-seconds across the transformer primary and a flux-imbalance in the core. If sufficient headroom is not allowed then transient core saturation can occur, causing excess current flow through the switches.
There is something called sub-harmonic oscillation that can damage SMPS's in this way if the control loop is badly designed!
In general problems like this can be prevented by:
1. Preventing rapid deep modulation of both the switching frequency or duty ratio. (This is essentially a control problem.)
2. Designing the transformer with some transient saturation headroom on top of that for normal steady-state operation. (This often takes care of itself if the transformer is conservatively designed: HF ferrite power transformer designs are usually constrained by core-loss not saturation.)
3. Gap the core very slightly to increase the saturation flux density.
4. Use small PP capacitors in the capacitive divider leg of the half-bridge. This means that imbalances in duty-ratio can be quickly absorbed by shifts in the mid-point voltage. (That's why the load isn't usually tied to the middle of the voltage doubler electrolytics.)
5. Use current-mode control to prevent flux-walking. Or at least peak switch-current limiting to prevent disasters.
If it were me trying to diagnose your problem, i'd pop a CT over the load wire leaving the half-bridge MOSFETs. Rectify the output of the CT, feed to a burden resistor and display the voltage on a storage scope. Run the circuit with no modulation, and turn up the scope trigger to a level where the current being measured is just too low to trigger the scope. Then gradually introduce audio modulation and see if it starts to trigger the scope. Any triggering shows that larger current pulses are flowing. You can determine how much larger, by how far you can increase the trigger threshold before the scope stops triggering.
If you have a decent scope with deep storage memory and a few channels you can scope the VCO and GDT drive too. Once you trigger on a overcurrent event, you can roll back the display to see what the gate drive signals were doing at that instant. This should reveal what is causing the problem.
If the waveforms are "jumping all over the place" with music as the modulator, then use a sig gen to produce a steady periodic modulating signal. Then the modulating frequency and the depth are controlable and repeatable.
I hope this helps,
-Richie,
Fri Sept 25 2009, 09:25PM
Thanks, but no storage scope here frown
As far as I understand, introducing some deadtime might fix the problem, but I'm not exactly sure how to simply implement this, the circuit needs to be compact and I already have 4 ICs in it...
Another way might rebuild the circuit as a single-switch forward converter, that should fix the problem right? But the thing is that with 330V on the dc bus and a 800V FET, I can't quite use the 50% duty cycle from the VCO...
GeordieBoy
Fri Sept 25 2009, 09:49PM
To be honest the idea of audio modulating a flyback spark via FM sounds a little bit dodgy to me! How is it that you think the spark intensity get's modulated by deviating the switching frequency?
I may be partly responsible for the proliferation of this FM singing arc idea though. I showed that you can use FM of the switching frequency of a CW SSTC to audio modulate the discharge. But, this only works because the Tesla Resonator used as the load is a high-Q tuned circuit. The TC resonator actually converts the FM into incidental AM as the carrier frequency rides up and down one side of the bandpass response. It is these amplitude variations that result which modulate the spark temperature and produce the audio. The inverter effectively outputs full AC voltage amplitude all of the time, and relies on "load modulation" caused by the FM to vary the current drawn by the load. (It just so happens that Frequency Modulating an inverter running at full power is easier than implementing true AM via high-level modulation, and it circumvents some of the problems with implementing it via PWM.)
The reason that FM sounds strange for modulating flyback arc intensity is that this method relies on a high-Q resonant response from the load to produce this "slope detection" effect converting FM to AM.
So, how do you think FM causes audio to be emitted from a flyback transformer arc? Are you relying on some resonance of the transformer windings? Or do you have some other resonant matching network in there between the inverter and the flyback transformer?
It just seems to me that PWM might work better for a flyback transformer. Or more specifically modulating the switch's on-time and using a fixed off-time for resonant flyback. The variable on-time allowing you to precisely control the energy stored in the core at the end of each on time.
-Richie,
