  • Guests: 189
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Some more TVS questions
Frosty90
Sun Sept 20 2009, 12:19AM Print
Frosty90 Registered Member #1617 Joined: Fri Aug 01 2008, 07:31AM
(In a seperate thread because they are a bit different)
My My current TC (incomplete) uses a bridge of hgtg40n60a4, which are the TO-247 ones without the internal diode. So obviously, I will have external freewheel diodes, in the form of u8100e diodes. I have also changed my mind, and want to put some tranzorbs there as well (better to be safe than sorry, the price of a tranzorb is less than an IGBT), but I was thinking, is this even a good idea?
During the conduction of the free wheel diodes, if I use unidirectional tranzorbs, are they likely to become foward biased? The data sheet for the 1.5ke series seems to indicate they have a slightly lower foward voltage curve than the u8100e diodes. Is this likely to be a problem? Whats the reverse recovery of a tranzorb like?
Also, am I right in assuming that the 'working voltage' rating is the nominal reverse voltage? So if i have a 340v supply, the 1.5ke440a (working voltage 342v, clamping voltage 548v and the max voltage of the 40n60a4 is 600v) will be the one to use?
Cheers,
Jesse
Mon Sept 21 2009, 09:41AM
From memory; this type of igbt will act pretty much like a TVS once it's Vce rating is exceeded, so if a TO247 on a heatsink can't dissipate transients, an axial diode package certainly will not.
My guess is that any marginal benefit of using TVSs everywhere would probably be outweighed by potential new problems.
(e.g. TVSs going short-circuit)
I often use TVSs but they aren't a cure-all.
IF the bus is low esr/esl etc then the freewheel diodes together with the bus act as 'spike' absorbers. Low inductance H-Bridge layout is worth researching.
Frosty90
Mon Sept 21 2009, 11:26AM
Thanks for the info, but i found some bidirectional tvs' anyway, even though its true that they shouldnt need to be used, its only a couple of dollars. I've found that even though MOSFETs and IGBTs should undergo break down and clamp voltage them selves, Ive had many mosfet deaths (IRFP460s) that certainly werent due to over dissipation (they were cold), and at the time i did notice quite a bit of ringing, so I put that down to overvoltage. You are right, they SHOULD clamp the voltage automatically and absorb the transient, but it seemed that it wanst happening that way. I dont know a huge amount about IGBTs, and how well they respond to overvoltage, so I put tvs' in anyway.
Cheers,
Jesse
GeordieBoy
Mon Sept 21 2009, 12:33PM
Yep, I'll second that. Choose the right switches and free-wheel diodes, and do a good job of the layout. Leave the TVS's for things like surge protection on power and data cables.
-Richie,
Mon Sept 21 2009, 12:40PM
Sulaiman wrote ...
Sulaiman, I appreciate what you've pointed out here. For a beginner like myself, it's all too easy to get carried away with enthusiasm for a particular component or circuit configuration, and I'm sorry if I gave others the impression that TVS diodes alone would solve all their spike and surge problems, which they certainly will not.
I should have written something like "for the forseeable future, TVS diodes are likely to remain an important element in any portfolio of surge and spike mitigation strategies."
Thank you for bringing clarity to the discussion.
Harry smile
Frosty90
Tue Sept 22 2009, 08:21AM
Haha, dont worry Harry, it wasn't you who pushed the idea into my head! I had actually been thinking about it from the start.
I do realise that low inductance layout etc are the best solution (treat the cause rather than the symptoms), and I have made an effort to build a low inductance bridge and I realize that tvs are somewhat of a 'bandaid' solution. But I figured it wouldn't hurt to put them in 'just in case', not as the primary way of removing spikes, but as a last resort. Anyway if they do cause problems such as going short circuit (but then agian, jsut about any component could do this and wreak similar havoc), I can easily pull them out.
Cheers,
Jesse
Tue Sept 22 2009, 11:43AM
Frosty90 wrote ...
Cheers,
Jesse
Hello Jesse! smile
you've hit the nail on the head for me, here! The thing is to design the circuits so they'll cruise effortlessly along without ANY transient protection, and then and only then add the TVS diodes/ MOVs/spark gaps as a probablistic safety feature.
Thanks for pointing out the way to better, cleaner design! smile
Harry
