  • Guests: 34
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Are these caps good for an induction heater tank
Sat Sept 19 2009, 02:12AM Print
I would like to know if the spec are reasonable. The voltage is good. I am not sure 13.5A x 6 caps is enough. I would put them in an array for 0.75uf. This would only be about 65A rms. I am not sure about the other specs.
This is this one, but it does not mention the current limits
Sat Sept 19 2009, 07:35AM
If you search the forum you will find that other members have had failures with CJE caps, they are basicly a cheap knockoff that will not live up to its specs, of the CDE 942C.
I unfortunately have 8 of them myself that I just bought together with some other caps long ago, I might put them to a real test in a small drsstc some day
