  • Guests: 22
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
Inductance question
StevenCaton
Thu Sept 17 2009, 09:32PM Print
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
Task: You are given a 15 foot long length of 22 gauge wire. You will connect this to a 100KHz AC source. How would you orient the wire to make it have the most inductance possible.
(No iron cores allowed, you can only bend the wire into turns.)
I was wondering about this today. I couldn't decide whether the lenth of wire would have more inductance if it had, say 5 huge turns, or 35 smaller turns.
If I had to take a guess at it, I would think that one should wind the wire in a multilayered solenoid coil, with many small turns on each layer, rather than several turns with a huge diameter.
I guess I could plug some number into one of those inductance calculators, but I don't really trust them to give me accurate answers.
Thu Sept 17 2009, 09:47PM
Not a trivial problem, but I agree with your inclination to use many small turns.
For cases like your examples, where the coil is practically a thin ring, the product of loop radius and turns count is constant. Inductance goes up as the SQUARE of increased turns count, and as a slower function (logarithm) of increased loop radius. Link2
[edit] For a single layer solenoid, the optimum is a stubby cylinder with length a bit less than its radius. See Link2
What I didn't have time to find (during break from day job) was a similar reference I once saw, that found the optimum for a multilayer coil with a rectangular winding cross-section. It's called a "Somebody" coil, but I don't remember the name, and it was stubby & thick.
[edit again] Don't let my boss know, but you want a Brooks coil. Ideally the winding cross section is a circle, to optimize the average coupling between turns, but a pretty close approximation is square cross section with thickness & length about 1.5 times the mean radius. So Steve, if you make one of these out of your specified piece of wire, what L/R time constant will you get?
jpsmith123
Thu Sept 17 2009, 10:43PM
Supposedly the "Brooks coil" configuration gives the maximum inductance you can get for a given length of wire: Link2
Thu Sept 17 2009, 10:55PM
Oops. It's not part of the original task, but since Steve specified 100 kHz
somebody should figure (or measure) the capacitance and self-resonant frequency
of a Brooks coil wound with the specified piece of wire.
WaveRider
Fri Sept 18 2009, 02:22PM
You want to maximise the mutual coupling between all the turns as well as the total flux per unit current enclosed by the coil (inductance equation: L*I = N*phi).
I would recommend a coil wound in the form of a toroid with the toroid diameter about the same as the winding diameter.... (This is a guess, mind you... no calculations today!) wink This is based on the fact that the toroid configuration has very low flux leakage wrt other coil geometries, hence inter-winding coupling should be quite high...
