  • Guests: 44
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Leakance
Tue Sept 15 2009, 02:16PM Print
Could someone kindly explain in a few simple sentences what we mean by the property of leakance, and it's basic formulae. Thank you,
Harry.
Tue Sept 15 2009, 02:37PM
I guess you mean in electronics, else there is also thermal conductivity.
Dr. Slack
Tue Sept 15 2009, 03:27PM
Some context would be handy here, Harry. Where have you read it? What field does it apply to? Do you know any of the units that go into its definition? "Leakage" has applications in thermal, electrical, hydraulic etc fields, though the -ance bit at the end seems to rule out the wet one of those.
Tue Sept 15 2009, 03:34PM
Leakance –noun Electricity.
the reciprocal of the resistance of insulation.
Tue Sept 15 2009, 04:17PM
Mads Barnkob wrote ...
Thanks Mads. Does it have its own units like mhos, or do we talk about it in percentages, and such?
Tue Sept 15 2009, 04:27PM
Slacks, leakance as a property, for example, of the glass outside of a thermionic device, where there is an anode top-cap, then glass of resistance, say, 10T, and then the kathode etc at the bottom. So is leakance a ratio between internal (desired) and external (unwanted) resistance in such a case? I'm still not quite clear about it.
Electroholic
Tue Sept 15 2009, 04:36PM
never heard of it, but if its 1/ohm, the unit would be Siemens also known as conductance.
Tue Sept 15 2009, 05:04PM
Harry wrote ...
It should all be in the wiki article I also linked to
Tue Sept 15 2009, 07:21PM
This is the first time I've come across the word 'leakance'
it sounds like leakage-conductance .
Dictionary.com says "the reciprocal of the resistance of insulation."
So It must be.
Conductance unit siemens = Amps/Volt.
So for 'leakance' of glass it may be uA/kV = nano-siemens
Dr. Slack
Tue Sept 15 2009, 09:15PM
I don't know why anybody would want to invent a new term Hazzer, conductance is well understood. If I wanted to know how much current flowed through an insulator, I'd measure it as amps per volt, and call it conductance. Would I ratio it to some undefined internal work current? Not if I was measuring an insulator or a valve base, but perhaps if I was measuring something for which the value of the work current was implicityl defined, like a valve. Indeed, that implicitly defines the voltage across the insulator as well. The -ance suffix makes it sound like it has dimensions, so leakance is a poor choice to imply a dimensionless ratio, if it is indeed the ratio of loss to work current. Loss ratio could be an alternative term.
