  • Guests: 41
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
transistor oscillator
Tue Sept 15 2009, 05:27AM Print
Here is an oscillator circuit I dug up
1252992275 190 FT17015 Cm Ih
I can use a DIAC to send a startup pulse to the lower transistor base to get it to conduct and start oscillations. I was hoping someone could clear up what prevents both transistors from simultaneously being in a conducting state, rather than switching back and forth.
Tue Sept 15 2009, 08:20AM
Looks like a kind of multivibrator to me, son.
Tue Sept 15 2009, 01:10PM
A royer push-pull oscillator? I am thinking the phasing of the transformer coils is responsible for allowing only one transistor to conduct at one time. I found a close circuit on the HvWiki, but no good explaination of one cycle.
Tue Sept 15 2009, 02:02PM
Honestly, Smoothie,. there's so few parts I'd just patch it together on the bench. and see how it goes. But I'd call it a kind of multivibrator - or push-pull gismo as you suggest - for want of better knowledge.
Tue Sept 15 2009, 02:54PM
Although not shown in the circuit diagram I assume that the two transistors are driven by the feedback windings - and one phase will be inverted with respect to the other.
Tue Sept 15 2009, 04:38PM
I figured the same. Other schematics I have perused through have the phases labeled.
Tue Sept 15 2009, 08:53PM
Would this be a good transistor to drive the oscillator Link2 ?
I need something with a high breakdown voltage. (450v)
It should handle 8-10A. (30A)
It should have a high gain (on page 4/8 it appears to have a gain between 10 and 20 for most of the range).
Fast switching.
I would just like it if someone could verify if this is a good choice.
kell
Thu Sept 17 2009, 03:58PM
kell Registered Member #142 Joined: Sat Feb 11 2006, 01:19PM
Smooth, obviously the bases get driven 180 degrees out of phase. If one gets driven on, the other must necessarily get driven off at the same time. Looks pretty fail-safe on the face of it, just have to see what happens on the bench.
I would note that you could probably replace the current transformer with a couple of feedback windings on the output transformer.
Building an induction heater?
