  • Guests: 30
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Lots'a UV LEDs
Solidacid
Mon Sept 14 2009, 03:29PM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
I'm building a UV exposure box for making PCBs, i'm building it on a stripboard and i'm gonna make it 7 by 7 LEDs.
now, how would i go about calculating the 7 required resistors for powering the LED's in 7 strings of 7 LEDs connected in series?
i'm planning on using a 230 to 2*12 transformer to get about 24 volts.
EDIT:
i didn't think this through AT ALL.
i have decided to just go with a 6 by 6 board.
would i be able to run this with a 10v 850mA transformer driving 12 strings of 3 LEDs in serial?
3 LEDs with a forward voltage of 3.3v each = 9.9v per string.
6*6 LEDs with a forward current of about 20Ma = 720mA total.
right?
Mon Sept 14 2009, 05:44PM
The 3 led strings would probably work, but you really need a some kind of resistor between the LEDs and the transformer, as the LEDs heat up the voltage drop changes slightly, which the resistor can help account for. If you have as 12v regulated supply (like a computer charger that puts out about 12v) around somewhere it would be ideal, you could add a 100 ohm resistor in series with each of the 3 led strings and maintain reasonable efficiency.
Also keep in mind that a transformer (as opposed to a regulated supply of some kind, like a smps supply) is not going to put out exactly 12.0v, but depending on the load, input voltage, etc, will put out a voltage of about 12v. Also if your transformer is not already rectified, you will need to do that which will further drop the available voltage.
Bored Chemist
Mon Sept 14 2009, 06:05PM
Can you get LEDs that give the right wavelength?
Mon Sept 14 2009, 06:53PM
Been there, done that. Link2
lpfthings
Tue Sept 15 2009, 05:45AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Exactly what you are looking for I think. I find it a very useful tool :)
