  • Guests: 26
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
BSM25GD120DN2E 3224 IGBT IH Working!
1 2 3 4  last
Gabriel35
Sun Sept 13 2009, 07:50PM Print
Gabriel35 Registered Member #2310 Joined: Wed Aug 19 2009, 08:04PM
Hi all!
I'm building the Kim Ladha's induction heater, and i think i got it working, but i still have some doubts
I'm not using Celem Induction Heater capacitors
The IH is already oscilating because the workpiece, workcoil, and tank capacitors are warming a little.
The WorkCoil have 4 turns...
1st- The fets(IRFP's460) heated pretty well with 30~40v @ 5,5A on the inverter part...(shouldn't they work cool?)
2nd- The current kept limited by the Zmatch inductor...does the current rises with more voltage?
3rd-I've noted is that the circuit don't get to oscilate if i use 5,6nF 10nF or 22nF capacitors between current transformer(100:1t aprox.) and workcoil part of the circuit, i just got it to oscilate with a 100nF or higher - 1000v ones, someone knows why? Can this fact be limiting the circuit in something?
Do you think that if i try to run the inverter part with 250vDC the mosfets can blow?
I have some photos of the work below, and the schematic if someone don't remember it:
Schematic idealized by: Karim Ladha
Any Ideas?
GeordieBoy
Sun Sept 13 2009, 08:09PM
You really do need a decent oscilloscope to diagnose what is going on here. In general if something in power electronics isn't working properly at reduced voltage, then it will likely go bang when you turn up the supply voltage. You need to get to the bottom of what's happening before you increase the power.
I'd also recommend you copy someone's design *EXACTLY* if you don't know what you are doing, then you have more chance of it working. Substituting different capacitors and power transistors is only a good idea if you know that these changes won't effect operation.
-Richie,
Gabriel35
Mon Sept 14 2009, 02:14AM
Should i have a couple of filter capacitors between rectified mains and inverter?
Hernan
Mon Sept 14 2009, 03:28AM
Hernan Registered Member #1614 Joined: Wed Jul 30 2008, 03:08PM
Gabriel, this is the circuit that I use:
It works very well and mosfets stays cool The caps between Drain and source form lossless snubbers and helps to keep Irfp460 cool but only works with inductive load
]ih.zip[/file]
Gabriel35
Mon Sept 14 2009, 03:46PM
Thank you for the schematic Hernan, it is a bit more complex that this one that I'm trying, and i think i don't have acess to some parts drawed on it...
If i really can't get nothing from the actual circuit i think I'll give up trying to build this thing...
this os the second circuit that i'm trying and i'm a bit tired already...
The workpiece is warming a lot with about 2 minutes of work (about 120ºC), with zmatch limiting the current to 1,5A @ ~34v(mosfets pretty cool)
if i change the zmatch and rise the current to 3,2A the fets get painful to touch with about 30 secs of working
Maybe this circuit is designed for using exclusively with IGBT's?
keeps my questions on the 1st and 3rd comments
Thanks!
Hernan
Mon Sept 14 2009, 11:24PM
Yes, I feel very angry I same situations when circuits doesn't works.I want to throw all away by the window.
I recommend to use a variac to slowly raise the voltage checking waveforms with a scope.
regards,
Hernán
Gabriel35
Tue Sept 15 2009, 01:29AM
yes, i feel that way sometimes, but the feeling os victory when everything is working, compensate the wasted time...
I Don't have a variac, how can I obtain one?
teravolt
Tue Sept 15 2009, 03:10AM
Gabriel if you want to do it on the cheap you could use a standard 600w light dimmer and a seies resistor (for current limmiting) and a capacitive doubler. I don't know what your buget is like but a good buget oscilloscope say 100MHz would be a must for this type of work
Tue Sept 15 2009, 03:33AM
I got my scope on Ebay a long time ago. There are some good deals depending on when you get one.
Gabriel35
Tue Sept 15 2009, 03:56PM
i have a 8800w dimmer based on TIC41 but it don't variates the output of the transformer, i think it just work on resistive circuits , like electric showers
1 2 3 4  last
