  • Guests: 14
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
Seebeck generator
Thu Sept 10 2009, 12:14AM Print
Dennis Rogers Registered Member #1837 Joined: Tue Dec 02 2008, 02:20PM
I just completed construction of a Seebeck generator (completely copied design from Make magazine 15). I'm looking for suggestions to convert my average 1.8vdc into 5vdc. I found this chip Link2,C1,C1003,C1039,C1133,P1383 but 2v is peak I've ever generated and I don't want to count on it.
Not looking for a handout here, just some suggestions. Would you go microcontrolled boost converter? 555 boost? Any suggestions appreciated.
Basically I'm using a Peltier cell in reverse. Heating one side, cooling the other and using the generated voltage to charge my ipod. (I hope)
Thanks for any suggestions,
Dennis
Bjørn
Thu Sept 10 2009, 03:12AM
I made a peltier termoelectric generator ages ago. I used a MAX856 chip Link2 to generate 3.3 V and 5 V. It started up at about 0.8 V and kept running down to about 0.5 V at reduced output power and voltage.
It requires few external parts but is a pain to solder without proper surface mount parts since some connections have a maximum length of about 5 mm.
Sparkfun has several ready built modules like this one: Link2
Thu Sept 10 2009, 08:31PM
Thanks Bjorn, that sparkfun module is exactly what I was hoping to find. I guess my search technique is lacking because I tried to find something like this for a while.
Thanks again, I'll update with pics when its operational.
Dennis
edit:
Update! Bjorn's suggestion worked perfectly. My generator will happily run at 5v all day (as long as the candle burns.) Oddly I had to eliminate the 5v fan, I guess it was drawing too much current, as I could never get to full conversion when it was wired in. That's even better though, no moving parts. Thanks again Bjorn and I'll update with pics in a few days.
Sat Oct 03 2009, 12:42AM
Here is the finished generator. I'm surprised the fan had to go but it's definitely more efficient now.
Th
Also here is my completed nixie clock from a while ago:
Th
