  • Guests: 39
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Feedback control for Induction Heater
Tue Sept 08 2009, 03:34AM Print
This is a circuit by Tonskulus: Link2
How does the 1:40 transformer connected to the Schmitt trigger control the circuit. This looks like a feedback to cotrol the frequency?
If I built a small 500w half-bridge unit with IRFP460 Fets how necessary is the feedback? I have seen designs such as this one without feedback. This one is not a resonant circuit.
Is it that resonant circuits need a feedback loop to prevent the resonant current from getting out of control as the workpiece affects the natural frequency of the work coil?
Tonskulus
Tue Sept 08 2009, 09:49AM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
Feedback is used because resonant frequency of tank circuit is not uniform, it always varies when different work pieces or work coils are used. And it also varies while workpiece heats up. So it is necessary to use feedback circuit to keep working or firing frequency matched with tank resonant frequency to get ZVS or ZCS operation. Thus, inverter stays cool and power losses are minimized.
If fixed frequency is used, there is risk for mosfet/igbt failure if inverter is undertuned (firing freq lower than resonant freq of tank circuit).
My circuit is actually self resonant or self excited. Small part of tank current is fed through the primary of current transformer. Schmitt trigger contains relaxant oscillator to start operatian and keeps system running but as soon as feedback signal is applied, it overtakes relaxant oscillation and now system is running in resonance (ZCS operation).
No, it's exactly the opposite. If you don't drive the induction heater at its resonant frequency, you won't get the high current needed to melt stuff. The resonant frequency changes as you insert the workpiece, and the circuit needs to track that. A simple feedback oscillator is the easiest way to achieve the tracking.
teravolt
Tue Sept 08 2009, 04:50PM
Steve McConner or Tonskulus have you guys tried a 4046 pll for this or is Tonskulus feadback work just as well
Wed Sept 09 2009, 09:31AM
Uzzors and I have both built induction heaters driven by the 4046. I think Uzzors' circuit looks pretty good.
