  • Guests: 55
Alex_FX (45)
Pieznice29 (31)
12/31 Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
90 - 100v booster ideas
HVPaul
Fri Aug 28 2009, 05:58PM Print
HVPaul Registered Member #2321 Joined: Fri Aug 28 2009, 05:13PM
Hi All,
I'm long-time lurker first time poster.
I'm interested in building an inverter or boost circuit of some kind to power a 90 - 100v
tubular neon indicator lights. Now this is very application-specific so the search I've done
hasn't turned up a solution for this type of case scenario.
This inverter is to be used to drive neon lights as power and HD indicator lights in a PC computer case instead of LEDs. My idea is to have common HV source driven either by the 5 or 12 volt rail boosted up to 90 or 100 volts DC and then use a transistor controlled by the motherboard's HDD pins to switch the neon light. Power neon will be driven directly off the HV.
I have found what seems to be a perfect circuit snippet for this purpose but I'm trying to fill in the blanks and find out in general how safe this solution would be. After all, computers are sensitive devices and i wouldn't want 100v transients entering the 5/12v rails.
Here's a snippet that intend to use. Of course adjusting cap and inductor values for the target
voltage.
I probably will use a 555 to drive the transistor and switch the output stage with another.
What are you thoughts? I'm very much a newbie when it comes to designing circuits so it'll probably end up in ashes :)
Here's another one that is a complete nixie tube power package. I've yet to figure out how to adjust its output voltage down
and what parts I'll need to control the output stage for switching the HDD neon.
Nixie supply
Any ideas guys?
I'm feeling kinda dumb suspecting that solution is staring me right in the face :)
1251482068 2321 FT0 Boostsch
1251482320 2321 FT0 Nixiedriver
Myke
Fri Aug 28 2009, 09:41PM
Is it one of those neon indicator lamps or one of those tubular CCFLs? If it's a CCFL, I would use a current driven royer. For driving a normal NE-2 type indicator, a buck boost converter using an inductor and a 555 should be fine. If you fear those transits on the voltage rails, you can put a zener diode across the rails with a current limiting resistor. Don't forget caps to smooth the supply voltage as well (something like 220uF and a .1uF cap)
Fri Aug 28 2009, 09:49PM
Welcome to the forum.
A plain boost converter 12V:90V will serve you well, and not put high voltage spikes on the supply rail.
Google can direct you to plenty of design notes.
For any design you need to start by specifying the minimum and maximum load current. If there's a guaranteed minimum (such as your power indicator or even a dummy load resistor), you can design for continuous current (in the inductor) mode. Then no need for voltage regulation -- a simple fixed-duty-cycle 555 circuit can drive your high voltage transistor for a fixed voltage boost ratio. Get a second HV transistor of the same type to turn your HDD indicator on and off. Can do fine with parts like Link2
It might be even simpler to use a separate inductor and boost transistor for each lamp. Simply place the neon lamp in parallel with the transistor (can skip the diode, capacitor, and current limiting resistor on HV side). Use non-continuous current mode, with average output current proportional to transistor on-time and rep rate. The two switchers can share a timer for base(gate) drive, with one also needing an enable signal from HDD activity. Could use a photo-isolator if you're feeling nooby and really want to play it safe.
jonny5
Sat Aug 29 2009, 05:41AM
jonny5 Registered Member #1807 Joined: Tue Nov 11 2008, 07:36AM
One disadvantage of simple boost converters: no inherent way to stop current flow from the input to output. If your boost experiences a shorted output, your computer 5V/12V rail is shorted as well (through the inductor and diode). A fuse would be a good idea. Flyback and buck-boost topologies are far more complicated, but the current-controlled versions can often tolerate a fault (i.e. output short circuit) indefinitely. You could always use a separate supply (wall-wart type?) for the boost, possibly saving your computer supply from a worst-case scenario.
Sat Aug 29 2009, 11:36AM
I'm all for an easy life, Paul, so if I lived in the USA, with a 110V mains supply, I'd simply knock that down to 90V. So long as a circuit is properly thought through, then the fewer the components, and the less likely to fail over time.
GeordieBoy
Sat Aug 29 2009, 12:07PM
> It might be even simpler to use a separate inductor and boost transistor for each lamp. Simply place the neon lamp in parallel with the transistor (can skip the diode, capacitor, and current limiting resistor on HV side). Use non-continuous current mode, with average output current proportional to transistor on-time and rep rate....
That is exactly how I would do it myself. Let the neon bulb act as the clamp for the flyback pulse from the boost inductor. Then it will effectively set the output voltage from the converter equal to the voltage drop of the ionised neon gas.
-Richie,
teravolt
Sat Aug 29 2009, 04:36PM
Im with Harry use a small stepdown transformer and make a power supply then use a mosfet to switch the voltage through the neon. you may also want to use a opto isolator to seperate your computer from the circuit. I'd be carefull about what you atach to your computer supply because any failure in your circuit could leed to computer death
Sat Aug 29 2009, 05:27PM
For switching, check out the MPSA42, it's a high voltage TO-92 transistor. I've seen them used in nixie clocks and the like.
To supply a neon lamp you normally want at least 150V, and a series resistor to limit the current. Neons are like LEDs but worse: they have a negative resistance, so the ballast resistor is compulsory.
I once built a 9V to 150V boost converter using the MC34063 with a high voltage switching transistor added on, in this case the MJE340.
You may want to optoisolate this whole mess from your motherboard's HDD activity line. smile
Heck, if you used optoisolators, why not just run the HDD activity light off the mains too? Neons meant for AC can look funny on DC anyway, because only one of the electrodes will glow, as Klugesmith demonstrated with his mechanical rectifier in another thread. And the MPSA42 is rated 300V, so it could switch 120V line.
HVPaul
Sat Aug 29 2009, 06:20PM
Wow, thanks for your insights guys!
I had no idea this would be so complicated. Seems like isolating option is
the best solution for this problem.
GeordieBoy: what would such circuit look like?
GeordieBoy
Sat Aug 29 2009, 09:21PM
Just like a normal boost converter, but with the neon bulb connected directly across the boost switch. No boost diode or output smoothing capacitor required.
Operation is as follows: When the boost switch is closed the current in the boost inductor ramps up, when the switch is opened this current transfers to the neon lamp and ramps down. You might need an RCD snubber across the switch to prevent spikes if the neon gas takes a while to ionise.
One seperate converter for each neon lamp.
-Richie,
