  • Guests: 50
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
differential op-amp
Wed Aug 26 2009, 04:34AM Print
I want to get the difference of two voltages. I will power the op-amp with one voltage. Any op-amp best for this, or will the LM3900 suffice?
aonomus
Wed Aug 26 2009, 04:44AM
Common op amps I like to use are: TL071, TL072, LM358...
Pick the one that suits you best, depending on voltages.
lhl_henrylui
Wed Aug 26 2009, 10:24AM
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
It depends on the voltage and current you want.
If you just need low cost,low power op amp, try LM741,LM358....
Renesis
Wed Aug 26 2009, 12:02PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
You might already know of this circuit, but im posting it anyway. It just seems like a much better way of building a differential amp from an op-amp.
Wed Aug 26 2009, 02:17PM
I was looking at several opamps and differential opamps at Digikey. Are there any with a single supply that will provide near 50v differential (IN1 - IN2) outputs. The ones I've looked at don't allow differences that high.
Wed Aug 26 2009, 02:45PM
No op-amp can handle an input differential greater than its total supply voltage, and some are much worse than that. For instance, the NE5534 can only handle 0.7V differential. You probably want to rethink your approach to the problem: in general, no IC can handle a voltage outside of its supply rails.
(hint1: an op-amp is not a differential amp, it requires 4 resistors to make it one)
(hint2: differential amps can have gains less than 1)
