  • Guests: 59
Hanzie (31)
badger (52)
h3X (40)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
H-Bridge Oscillator Debugging
dude_500
Tue Aug 25 2009, 04:48AM Print
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
I'm making a basic h-bridge oscillator for switching up to 220V based on the IRS2453 chip. I have built the whole circuit but it doesn't seem to be oscillating or doing anything really. The Output shows no DC or AC voltage and no frequency on my meter. Is there anything wrong in my circuit design? This is the first time I made a circuit of this type. There is 15.1V DC at the power pins 1 and 2 of the IC.
MOSFET's are 44N50.
One thing I'm not positive about is what to do with the pin 5 on the chip which is currently not attached to anything. It's the shutdown pin and there seems to be minimal documentation on it in the datasheet.
1251175707 2288 FT0 Capture
Bjørn
Tue Aug 25 2009, 05:26AM
The datasheet says "When the SD pin is brought above 2 V, the IC goes into fault mode and all outputs are low. VCC has to be recycled below VCCUV- to restart the IC."
So if it ever triggers the chip will not work again until you turn the power off and back on again. Connect SD to pin 2 (COM) to make sure it does not shut down and see if that helps.
dude_500
Tue Aug 25 2009, 06:53AM
Thanks, that did the trick!
stress
Mon Mar 11 2013, 09:06PM
stress Registered Member #10265 Joined: Mon Feb 25 2013, 08:16PM
can you please tell me what is the value of c7 and c8 for an 50Hz output?
Tue Mar 12 2013, 12:04AM
stress wrote ...
Welcome.
I didn't expect it would go down to 50 Hz, but the datasheet
(first result of a Google search for IRS2453) has formulas and charts that go that far.
Would love to hear more about your project.
stress
Tue Mar 12 2013, 12:17AM
my project is here, let`s talk about it there: Link2
stress
Tue Mar 12 2013, 12:20AM
about the c7 and c8 i have read the datasheet but not understand what is the value for 50Hz
thanks for your your time
stress
Sat Mar 23 2013, 09:57PM
anybody know?
