  • Guests: 53
Flyback Transfomers
Bead
Tue Aug 25 2009, 03:20AM Print
Bead Registered Member #2303 Joined: Mon Aug 17 2009, 05:51AM
I'm working on a small flyback circuit, but the problem is I can't find a flyback to use. I have a little one from work that I have been trying to figure out the pinout on, but have been unable to. I might just have to buy one and was wondering if anyone has a specific model that they would recommend for use, preferably one that has schematics or a pinout. Thanks.
Circuit I am working on:
Flyback that I have now, it came out this type of monitor Link2
(warning 2 meg image below)
Thanks for any help you can provide.
MRacerxdl
Tue Aug 25 2009, 04:27AM
About the pinout, forget it about. Most cases you dont need to know, you can find what is the pin by turning on and pulling arcs (the good flyback secondary ground will give you the biggest arc), so just wind 5-10 turns on the exposed flyback core, and with caution look for the pin that get the biggest arc. I always do that for finding the ground pin, the other pins I dont use (feedback coils, and so). Good luck =D
Tue Aug 25 2009, 04:30AM
The easiest thing to do, is to make a new primary winding on the exposed ferrite core and the rest should be described in the HVWiki: Link2
