  • Guests: 63
What the heck is that thing?
Voltwad
Tue Feb 17 2009, 04:16PM Print
Voltwad Registered Member #1829 Joined: Sun Nov 30 2008, 01:06AM
Here's an interesting xformer I found.
1234885430 1829 FT0 Hpim1378
It looks like it might be some kind of push pull inverter or something. I pulled this out of what must have been a mid seventies era console tv. Here's how it was hooked up.
1234886254 1829 FT0 2corexfrmr
The two chokes on either side of the xformer are small toroids with about 30-40 turns. That's the best I can do for a schematic. When I say 'pulled' I actually mean kicked, as I kicked the board out of the set when I found it behind a dumpster and the board is all kinds of broken. I can't tell if the core is gapped. It whines when I connect it to my zvs driver at full power. Anyone have any thoughts? Also Here's the flyback that came out of the set.
1234887252 1829 FT0 Hpim1379
Anyone ever seen a set of coils on the second leg of a flyback? At least the core is nice and beefy with a large winding window for winding my own.
Tue Feb 17 2009, 04:33PM
I have seen the triple coil thing in an old TV too, I think its a magnetic amplifier (simply said, the middle control winding applies DC flux to the core so it can control the saturation voltage on the outer windings).
That's a big core, dunno what the extra winding is for, probably they wanted extra leakage inductance on it so thats why its on the other leg.
Electroholic
Tue Feb 17 2009, 06:18PM
Sometimes they dont have a seperate SMPS in for the low voltage section and just have another winding on the flyback.
Tue Feb 17 2009, 06:24PM
Electroholic wrote ...
Yes but if they wanted good voltage regulation they'd have put it on the axis of all other windings.
That winding seems to have a lot of turns, maybe screen or focus?
Voltwad
Tue Feb 17 2009, 07:43PM
There's actually an inside winding that runs the length of the leg and then the outer windings are several, some only a few turns and some almost 1/3 of the length of the leg. I'm also trying to find anything on mag amps. The thing that I have has, I'm guessing 500-1000 turns on the 'secondary' and 5-6 turns each on the 'primaries' but this doesn't seem to match the few diagrams I've been able to find of mag amps. It works well on my zvs circuit as a push pull xformer though.
Tue Feb 17 2009, 08:29PM
The control winding has a lot of turns to be easily controlled with DC voltage, because what limits the current is only the DC resistance of the wire. Otherwise you would need milivolts and tens of amps to do anything.
Wed Feb 18 2009, 02:58AM
It's a DC biased variable permeability inductance, where the inductance is varied by the current through the control winding.
GeordieBoy
Thu Feb 19 2009, 10:56AM
I believe these magnetic amplifiers are a cheap and cheerful way of applying something called pincushion correction to CRTs with a large deflection angle.
It's something to do with modulating the amount of horizontal deflection with a bit of the vertical deflection signal I think. If you don't do that properly, then the corners of the picture either "pull-in" from the corners of the tube, or they curve outwards into the corners of the screen, buggering up the nice geometry of whatever image you are trying to view.
I think there is at least one TV repair man on here, so he might be able to explain how that component works.
-Richie,
Wolfram
Thu Feb 19 2009, 02:03PM
There is some information on the subject here: Link2 . See especially under "Horizontal Linearity Correction" a bit down on the page.
The waveform becomes a damped sinewave, which will be 'undamped' by restoring energy during the flyback.
One way to deal with this is to add a magnetically biased saturable inductor in series with the horizontal deflection yoke. This is called the linearity coil.
Its core is magnetically biased near the point of saturation such that the inductance decreeases with increasing current and this helps to stretch the right hand side of the scan. In other words, during the scan the coil saturates so that the inductance decreases. At the end of scan there is practically no voltage left over the linearity coil so that the deflection coil gets maximum voltage.
Anders M.
Zeus
Wed Aug 26 2009, 05:26AM
Zeus Registered Member #2316 Joined: Tue Aug 25 2009, 03:04AM
It is a pincushion tranaformer. If you check on a CRT monitor menu you shoud see
an option to change it. Also if you cut the wire between the two small windings
and drive it with a push-pull driver you shoud get 1Kv.
