  • Guests: 34
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Transistor Basics
cduma
Wed Aug 19 2009, 04:06PM Print
I have taught myself almost everything I know about electronic design except for some of the finer points of resistor-resistor (school taught me the finer points) networks. I am far from an expert but, I do know alot about the basic(R, L and C) components. It is turning out to be very difficult to learn about transistors. Every website I visit describes everything about transistors in great detail but, I need a brief summary instead of an in depth analysis to get started. I have purchased several text books and those are even worse than the websites! The most valuable tools so far to my learning have been connecting a pot to the base of a transistor(I learned to start at a lower voltage since some draw more than 1/4 watt. The magic smoke came out of the pot and it didnt work to well anymore) and measuring the voltage drop across the emmiter and collector although all I learnt was that transistors do what transistor do. Regulate current based upon the input. Are there any websites that you know of that can help me? I tried doing my own research but, I failed.
IntraWinding
Wed Aug 19 2009, 04:41PM
The Art of Electronics 'Transistor Man' might help. One of my favourite books years ago.
Wed Aug 19 2009, 06:41PM
cduma wrote ...
MOSFET - Control lots of current using a little bit of voltage
BJT - Control lots of current using a little bit of current
cduma
Wed Aug 19 2009, 07:14PM
Thank you both! Thanks intrawinding for the large amount of information and thanks Dr. GigaVolt for the ultracondensed information. If only there was an in between...
cduma
Wed Aug 19 2009, 07:46PM
