  • Guests: 30
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
LED spotlight pointer
Sun Aug 16 2009, 09:42AM Print
Hi all.
I noticed that many of my problems are due to inadequate lighting as my overhead fluorescents are useless.
Thought "wouldn't it be useful if I had an adjustable pointing light that focussed on the workpiece"
Current plan is to use a pair of small geared motors with Hall sensors to point a 10W LED with adjustable lens mounted on the ceiling, with a remote to control it.
Possibly use the PCB from a dead model heli as the controller as it already has motor drivers.
sound useful?
-A
Sun Aug 16 2009, 04:26PM
Conundrum wrote ...
sound useful?
Hardly.
What you need is a headlamp, the foxfury line has worked good for me: Link2
Cheers, Finn Hammer
Sun Aug 16 2009, 08:53PM
No, what you need is a desk lamp. smile
Or better still two desk lamps, one on each side of the workbench.
Mon Aug 17 2009, 07:53PM
I favor a long fluorescent lamp, on the underside of a top shelf.
Shielded from direct light in the eyes, lots of diffuse light.
Bright, reliable, cheap, energy efficient......
A small bright torch is very useful too.
Mon Aug 17 2009, 09:01PM
Your idea sounds overly complicated :D
As steve said, get a couple of desk lamps that uses good old 60W lightbulbs, stay away from energy saving ones.
Dr. Slack
Tue Aug 18 2009, 02:12PM
The problem with a point source of light tends to be shadows, and a remote control that you have to drive manually sounds like a real PITA. Now if your project was to have eye-tracking stuff so it would illuminate whatever you looked at ...
My bench light source is 4 short flourescents under a shelf, shielded from my eyes, to approximate to an area source of light to guarantee no shadows.
Jrz126
Tue Aug 18 2009, 02:47PM
Skytron sells an exam light usually used in labor and delivery rooms. The heads are motorized and will auto-focus on a strobe light wand. So you just hold this wand where you want the light and it'll focus on it.
The whole thing sells for around $10k
Tue Aug 18 2009, 03:16PM
I'd also say a fixture with a couple of 6000K fluorescents hung from the ceiling above your bench might be a good idea.
