  • Guests: 54
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Linear Motor + Optical Encoder - what to do with these I wonder...?
thedatastream
Fri Aug 14 2009, 03:00PM Print
Donated from a colleague, ex mixing desk
Linear motor - lots of magnets inside shaft, coil on outside of shaft
Optical encoder strip at bottom
Any ideas for what to do with them? Something with lasers and an arduino perhaps...
James
1250261962 505 FT0 Img 3322
1250261981 505 FT0 Img 3323
1250262007 505 FT0 Img 3324
Fri Aug 14 2009, 03:49PM
You can use the optical encoder strip as a very coarse diffraction grating.
Shine a laser pointer through it and measure the (small) divergence between spots.
Then you can determine the encoder pitch from the laser wavelength, or vice-versa.
lhl_henrylui
Fri Aug 14 2009, 04:32PM
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
If you have two, then you can make a two axis CNC!!!
aonomus
Fri Aug 14 2009, 05:26PM
I don't think those have enough force for a 2 axis CNC, although you could try something hackish and make a mechanical VU meter...
tobias
Fri Aug 14 2009, 08:51PM
tobias Registered Member #1956 Joined: Wed Feb 04 2009, 01:22PM
Why not a 2 axis CNC with laser head as a engraving machine?
No force required! And you can even made PCBs with it... check this out:
thedatastream
Sun Aug 16 2009, 06:50PM
Thanks for the ideas guys, I like the idea of a mechanical VU meter - especially if you attached an RGB LED to do the colours!
The encoder strip has the number 127 engraved on it so it could be 127 per inch. I guess the holding force would be similar to a stepper - easy to determine by hanging off a weight from the slider arm.
I think I'll hang on to them until I an think of a really good use for them
Hazmatt_(The Underdog)
Sun Aug 16 2009, 11:52PM
I would definately make some sort of positioner with them. Don't take them apart, they're more valuable intact. I think a micro mill would be really sweet!
Mon Aug 17 2009, 10:09AM
Looking at the pictures, the linear encoder seems pretty coarse. After all, you can see the holes in the strip! I don't think it would give enough resolution for CNC work.
