  • Guests: 44
Comparator question. [Moved from EM Projectile]
GODSFUSION
Wed Apr 12 2006, 10:37AM Print
GODSFUSION Registered Member #157 Joined: Sun Feb 12 2006, 08:00PM
Do I just use a straight voltage dicider with resistors off the cap connections, to the comparator? Or is there some curcuit that idealy should be made?
- Wayne -
Dr. Shark
Wed Apr 12 2006, 11:36AM
I dont know what you are trying to achieve here, but it might be a good idea to put in an optoisolator to avoid connecting the logic directly to the power electronics. Other than that, yes, it should work.
williamn
Wed Apr 12 2006, 04:11PM
williamn Registered Member #55 Joined: Thu Feb 09 2006, 04:56AM
If you are talking about using a comparator to sense you bank voltage(in order to regulate charging) then yes a VD across the cap will work fine. Its the way I did it. Just make sure you use very high values, so you dont bleed your cap too quickly.
GODSFUSION
Thu Apr 13 2006, 04:27AM
William yes. I havent hada lot of time to myself and no money so im taking apart my first coilgun and *upgrading* it if you will. Its been a couple years but it still works fine.
It was a halfbridge charged capacitor set up. I used my DMM to shut off the charger at 90% and fired with a marine curcit breaker switch.
- Wayne -
