  • Guests: 68
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Difference between the near field and far field
chadj2
Thu Aug 13 2009, 09:03PM Print
chadj2 Registered Member #2290 Joined: Thu Aug 13 2009, 08:15PM
I am studying electromagnetic radiation. I am currently trying to understand some of the
differences between the near field or the storage field; and the far field or the radiation
field. I understand that power is transferred in the storage field such as in in the case of a
transformer with the magnetic field coupling between the coils. If you increase the power
output through the secondary coils, you will have more power drained from the primary coil in
the form of increased current flow. However, when it comes to the radiation field, power is
radiated rather than transferred such as in the case of a television transmission tower. It
doesn't matter how many television sets are tuned in to the frequency, the station doesn't have to
increase power to compensate. I have read that it is hard to determine exactly where the
radiation field starts to become predominant and the storage field stops, but my main question
is this. Is the radiation field a component of the storage field or is it completely seperate
from the storage field? Does the radiation field take from the storage field or is it a
completely seperate phenomenon having to do with a charge accelerating or decelerating? I know
this may be a dumb question but I am just curious if this has been addressed before. I haven't
been able to find the answer in my own search of books and the web.
Chad
Fri Aug 14 2009, 10:01AM
If you think of it in terms of complex potentials, the storage field is the imaginary part, the radiation field is the real part. It's as simple as that. Power can't be transferred by the storage field: any time it's being transferred, there is a real component to the field.
The radiation field is not necessarily the far field, because EM power travelling through free space must have an impedance of 377 ohms. You can have radiation fields whose impedance is far from this, and they can't travel in free space. This is what happens in the transformer, Tesla wireless power, and so on. It's not a storage field (that would be the field associated with the magnetizing current) but it's not a radiant field either.
Paul Nicholson explains this by saying that the apparatus forms a cavity or waveguide with an impedance different to free space. For instance, when two Tesla coils are coupled capacitively, the field transferring power between them has a characteristic impedance of hundreds of thousands of ohms, on account of the high voltage and low current.
And yes, if you surrounded a TV mast with an enormous sphere of TV sets, they would absorb most of the power. smile You should read Nicholson's article on non-Hertzian waves.
chadj2
Fri Aug 14 2009, 06:21PM
Thank you for your quick explanation. I will be sure to search for that source you recommended.
Chad
WaveRider
Sat Oct 24 2009, 09:16PM
The difference between near field and far field is a bit of a fuzzy one. In a nutshell, whenever you have something with time-varying currents flowing on its surface, electric and magnetic fields are produced in the surrounding space. These fields exhibit two forms of behaviour. On one hand, the local "near fields" do not go anywhere...they look a lot like static fields and contribute to reactive power only; circulating around the structure. They typically die off as 1/r^2, 1/r^3, etc. as you move away from the current source. On the other hand, the radiation fields decay ar 1/r from the structure and contribute to power loss by power flow away from the structure. At a distance where the intensity of the radiation fields exceed the intensity of the stationary reactive fields defines the "far field" region.
Hope this makes sense...
Cheers!
