  • Guests: 76
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Calculating Effective Resistance (DC) of Thermal Pad - NEED HELP!
Mon Aug 10 2009, 05:54PM Print
I'm pretty stumped on this one. Basically, i have a thermal pad material which has an volumetric resistivity of 100 ohms*meter. The pad is 0.127 mm thick and covers a square area of 10^cm.
I'm trying to calculate the effective resistance of the entire pad, but am having lots of trouble. According to ASTM C611, this volumetric resistivity of 100 ohms*meter is basically the resistance measurement (using a 4-probe meter) of two opposing sides on a 1 meter cube.
I've tried scaling, but my results don't make sense and the units don't cancel properly.
Any help appreciated if you've run into this before.
Thanks
Dr. Slack
Mon Aug 10 2009, 06:53PM
The resistivity is in units of ohm * metres.
The resistance will increase as you increase the length, so length goes on top of the equation.
The resitance drops as you increase the area, so area (=m^2) goes on the bottom.
so the geometrical factor has dimensions 1/m
et voila, R = resitivity * length / area, in units of ohms.
So for your actual unit (take care of which m means metres and which milli, should be clear from the context)
R = 100 * 0.127m / - - - - and there I had to stop typing, as I don't know whether 10^cm means 10cm * 10cm (100cm^2 = 0.01m^2), or 10cm^2 ( = 1m m^2 = 0.001m^2 )
Mon Aug 10 2009, 09:47PM
Thanks for the help. Thats it. I did manage to figure it out and it turned out more simpler than i thought. (The equations were just staring at me!)
Vp = (Area/Thickness) * R where R is the measured resistance and Vp is volumetric resistance.
Makes perfect sense now! :)
