  • Guests: 27
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
100W LED
Mon Aug 10 2009, 05:19PM Print
Hi all.
I got one of those 100W LEDs that TDU published a write-up about.
Was looking into using liquid cooling as it might make things less cramped.
Current plan is to use some surplus tin/lead plumbing solder (as its now banned from use for plumbing) and air con tubing as a cooling block.
Has anyone tried this? I did some tests and it seems that it should work (lots of small tubes = much heat flow) and making the contact area of the block from silver/tin alloy should improve the thermal conductivity.
regards, -A
Mon Aug 10 2009, 05:59PM
Do you have the link to the original write-up?
If so, please post it!
Thanks
lpfthings
Mon Aug 10 2009, 10:07PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Link2 W LED
Tue Aug 11 2009, 01:37AM
There is also a thread here on 4hv Link2 that has more info.
In any case, soldering a few passes of copper tube to a block of copper should work well, although easier than putting the tubes in parallel is just using a few loops, and all other things constant you will have about the same amount of heat difference between the hot/cold end of the pipes.
Good luck!
Tue Aug 11 2009, 02:35AM
Conundrum wrote ...
Current plan is to use some surplus tin/lead plumbing solder ... as a cooling block.
Are you talking about a 2-layer block of fusible metal: silver solder contact surface, backed by tin/lead that embeds the coolant tubes?
Ought to work, but wouldn't it be easier (and work better) to make your cold plate out of copper or brass, and solder the coolant tube on back surface? A rough contact surface, or other interference with thermal contact to LED module, would be more significant than which metal you use.
I'd suggest you make some simple thermal resistance calculations before cutting any metal. Look up the metal resistivity (degrees/watt * cm), multiply by heat path distance (LED interface to water), divide by heat path area -- that'll give you estimated degrees per watt. The conduction-cooling path wattage is probably between 1/2 and 3/4 of the electrical input power.
MinorityCarrier
Tue Aug 11 2009, 06:24AM
Use something like these water-cooled copper heat sinks
1249971779 2123 FT74082 Img 1894adj
Fraggle
Tue Aug 11 2009, 09:41PM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
It would be better to have a solid plate of copper, larger than the LED and a few millimetres thick, with the tubing soldered to it then clamped to the LED. I may have a suitable piece if you need it. If the water is too close to the heat you`ll have to pump it quite quickly.
aonomus
Tue Aug 11 2009, 10:10PM
Think about using a vice to flatten the tube somewhat (filled with sand and curves already bent) so that the surface area of contact is larger. Otherwise, copper plate, and solder fill should do ok...
Tesladownunder
Wed Aug 12 2009, 04:31AM
Really a computer heatsink with attached fan is available at most computer shops and even a modest one will cope with the 80 W dissipation. Or get a heat pipe one that overclockers use.
Mine works fine except I smashed a blade and had to chip off opposing blades as a temporary fix.
Interesting that none of about 5 or 6 physicists guessed what it was when I showed it at the Uni Open day a few days ago. I usually like to bring along something that stumps the clever guys.
Wed Aug 12 2009, 06:36AM
Wouldn't iit be more prudent to use synthetic jets, a tried and trusted method of cooling LEDs of this size, rather than risk the diode burning up while these speculative cooling proposals are tried out on it?
