  • Guests: 50
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
FET's of same brand, but wont work!
OiD
Fri Jul 31 2009, 07:54PM Print
OiD Registered Member #2150 Joined: Tue Jun 02 2009, 08:33PM
Hi all.
I dug up an old project, and I needed to buy 8 IRFZ44N FET's.
This isn't the first time this has happened, the new FET's wont work in the circuit.
I don't understand it;
Old: International Rectifier IRFZ44N (331G AC 36) and IRFZ 44N PHm (0449 C7 8434)
New: International rectifier IRFZ44N (514L 5T 34)
This is the third time I have bought new FET's and not one of them worked. A cording to the shops they tested them and they were ok.
The FET's are controlled by a PIC (5V) to control some LED strips (12V).
Could someone explain what could be happening?
Or a simple circuit to test the FET's?
Thanks!
Fri Jul 31 2009, 08:08PM
they could be counterfeit, this has happened to several people who publish articles in "Television" and one in EPE.
best bet is to check one to see if they behave as expected out of circuit, ideally on a Peak Atlas or other transistor analyser.
-A
OiD
Fri Jul 31 2009, 08:52PM
Hi Conundrum, I buy the FET's at a shop in the city, I don't know what you mean by "EPE".
According to the data sheet the gate voltage can be +/- 20v from source.
Could a simple circuit test if the are working or not?
Common ground and applying +5v to gate?
Thanks. This is really driving me crazy. I had to put the project aside last year. All the parts for the project are from the same shop.
Fri Jul 31 2009, 09:36PM
what sort, enhancement or depletion mode?
Most FETs begin to turn on around 2-5V gate voltage, a simple LED and resistor from drain to +V will work
Fri Jul 31 2009, 09:39PM
Yes.
First, hook the gate and the source to common ground, and +12 volts to an LED with a current limiting diode, and then connect that to the drain. The light should not come on. Now hook the +12 straight to the gate, as well as through the LED and resistor to the drain. Hook ground to the source. This time, the LED should turn on.
The MOSFET may need 12 volts on the gate, though as long as it is low frequency i cannot see this being too big of a problem.
MinorityCarrier
Sat Aug 01 2009, 12:40AM
The threshold voltage, Vt, and the RDSon are two parameters you can check against the data sheet for the part. For Vt there is a minmum drain-source current spec for a specific gate-source voltage. RDSon is spec'd often at 25 deg. C, so don't run a lot of current through the device when checking that.
The AC parameters for running a light bar are not demanding, so I wouldn't focus on device dynamic characterstics.
There is a big problem with counterfeit power MOSFET parts spewing out of China, my company has had it's fair share of dealing with this.
OiD
Sat Aug 01 2009, 04:10AM
Don't know, I can't find it in the data sheet. :(
I've built a simple test circuit, my old FET's work, and a variety of other power FET's I have. The new ones do nothing :(
Ugh. Sounds like I've been getting counterfeits... but I guess the shop would get complaints, as they seem to sell and restock them.
Could they be dead by ESD?
Thanks all.
1249099824 2150 FT73659 Fet
MinorityCarrier
Sat Aug 01 2009, 05:02AM
Enhancement mode N-ch.
If the gate is not shorted or leaky to the source, probably not ESD damage. Judging by your circuit, with Vgs of 12V and source at Vrtn, kinda says that everything is open.
You can pull up the data sheet on International Rectifiers' Hexfet site
Maybe you should order it from International Rectifier, Newark or Digikey or someone you trust. Meanwhile I suggest you break open one of these suspect parts and see if there is even a die in there.
Sat Aug 01 2009, 06:55AM
OiD wrote ...
You can find almost any datasheet at alldatasheet.com Link2
OiD
Mon Aug 03 2009, 11:02PM
Thanks all, I took them back and have managed to scrounge up a heap of odd FET's.
The shop said they will look into it and tell me.
Thanks again!
