  • Guests: 51
Air breakdown voltage variability
Sun Jul 26 2009, 05:02PM Print
If I set a safety spark gap to fire at x volts, how much variability of firing voltage should I expect for different air moistures, temperatures etc.?
Sun Jul 26 2009, 05:41PM
There's a lot of research on this very subject in the scientific literature. Google will readily find it for you. smile
Sun Jul 26 2009, 07:03PM
[quote]
[/quote]
Increasing humidity will increase the breakdown voltage necessary to arc.
Temperature really isn't a good parameter for variability. Its more correct to say variability in terms of density of air which is affected both by pressure and temperature.
Google Paschen's Curve. This will give you some background into what you seek.
blackgrunge
Sun Aug 09 2009, 04:51PM
blackgrunge Registered Member #1889 Joined: Mon Dec 29 2008, 07:36AM
Great question because my friend and I are writing our final physics paper on it! If you figure it out be sure to shoot me a PM wink
Sun Aug 09 2009, 04:58PM
blackgrunge wrote ...
Whats the issue? Its called Paschen's Curve. There is nothing to figure out. Its an extremely straightforward relationship.
Sun Aug 09 2009, 05:33PM
But the humidity isn't implemented in the Paschen's law...
Fraggle
Sun Aug 09 2009, 06:14PM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
Just do an experiment - there`s nothing like plotting a lovely neat graph for clearing the mind :o)
Sun Aug 09 2009, 06:23PM
Dr. Kilovolt wrote ...
E. Kuffel has done extensive studies on the effect of humidity and breakdown voltage. A search on IEEE archives should bring up some of his research and studies.
Humidity is a bit more complex and the effect is has on breakdown voltage varies substantially as the electrode geometry changes. (i.e. different sized spheres, etc...)
Sun Aug 09 2009, 07:09PM
Hi Kilovolt
The "Paschen breakdown voltage" - by which I mean the voltage at which the insulation of air breaks down leading to a Townsend avalanche allowing ions to flow across the gap - is probably good enough for general purposes, but does not take into account the pre-discharge state, especially variations of leader growth due to impulse rise time and the geometry of the gap,
To the best of my knowledge, the length of the coronal phase of dielectric breakdown in a gas varies with the impulse voltage wavefront, which happens because of the space charge caused by electric field distortion - the space charge itself being produced by the initial corona. The effect of this space charge is to create a statistical time delay in the breakdown of the gap. In a word, it is impossible to calculate the precise time at which a gap will break down, but only to talk of it in terms of probability, and greatest likelyhood.
Even the source impedance of your high voltage supply can influence the breakdown behaviour of your gap, so while we get the impression of a spark as a single snap and a flash of light, what we are seeing is not a single event at all, but a complex sequence of intertwined events each one of which is subject to what I'll call mini-variables.
As for safety gaps, I'm all for an easy life, and would just take one out of the box and solder it in. smile
blackgrunge
Mon Aug 10 2009, 04:02AM
Harry wrote ...
Hi Kilovolt
And as for "extremely straight forward".....get owned
