  • Guests: 66
Flyback Driver Kit Help
blackgrunge
Fri Aug 07 2009, 06:52PM Print
blackgrunge Registered Member #1889 Joined: Mon Dec 29 2008, 07:36AM
So I have built now my third flyback driver and despite finally buying a kit with everything already 'ready to solder' I keep getting the same results. When I turn on the flyback nothing ever happens but as soon as I turn it off it arcs to the negative lead. I understand that its the coil discharging because of the collapsing magnetic field but I'm still not getting the continuous spark its supposed to produce. I'm using a 24v DC input for the circuit and I followed the exact schematic provide by the kit (555 timer for the frequency control). Sadly enough even when I build my transistor driven flyback it still yielded the same results.
Any ideas?
Fri Aug 07 2009, 08:51PM
Have you checked your switching transistor? To me it looks like its shorted.
Fri Aug 07 2009, 09:20PM
Pictures? Schematics?
We need to know the part number of the switching transistor. If you are using a BJT, you may want to switch to a mosfet, they seemed to die less on me when i first built flyback drivers. I never use BJTs, only mosfets and IGBT's.
Fri Aug 07 2009, 09:21PM
I don't know what your circuit is,
but a 555 is rated for 18V maximum,
so unless there is a separate/lower voltage supply for the 555, it's probably dead.
blackgrunge
Sun Aug 09 2009, 05:26AM
@Sulaiman
There is a voltage regulator in the circuit for the logic ICs if you take a look at the schematic posted in the pdf a little ways down this post.
@Arcstarter
So I took a closer look at the part number for the 'high voltage transistor' (or so it was listed as) in the kit and much to my surprise it was an IGBT. Which is nice because they usually do better than regular transistors or even MOSFETs at higher voltages. But the downside is their Emitter-Collector breakdown voltage quite plainly blows (24v for mine). So I assume when I plugged in that 30v DC power supply to the board hoping it could take another 6v and the rtards who built it didn't borderline their design I was tragically wrong sad Now I'm going to see if I can replace the original 390v IGBT with a bit more robust 500v MOSFET that I pulled out of an old TV set board and hopefully that will work.
Oh and here's the kit schematics and pics and stuff: Link2
The part number for the IGBT which the kit came with is V5036P Datasheet: Link2
The one I'm going to try and replace it with is 2SK2662 Datasheet: Link2
Let me know if it will work because I figure it will because of the vast similarities between IGBTs and MOSFETs.
@Dr. Kilovolt
You were spot on. Totally forgot about that but turns out your 100% correct.
By the way, thank you guys for the quick responses and the very helpful suggestions.
CT2
Tue Aug 11 2009, 05:27PM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
It doesn't make sense to power the low power side (the side with the IC's, the 555 and 4049) with 24 volts, because then the Vreg needs to burn away 19 volts at what ever current the circuit uses, which most likely means it will get VERY hot and shut itself off. This part of the circuit should be powered from a 12V supply or less, the way it is wired now it only gets 5 volts anyways.
Also I don't think you got your Emitter-Collector breakdown voltage right, if you said you have a 390 volt IGBT then that is the Emitter-Collector breakdown voltage. The 24 volts should be from the Gate to the Emitter, and with your circuit it won't ever see above 5V. Now I'm not entirely sure but I would think it would be better to drive the IGBT with more then 5V but you would have to look at the datasheet.
The HV side of the circuit should be powered by 24 + volts, but that should be kept seperate from the control side as I said before.
EDIT
Just checked the datasheet you linked, and yes the Emitter-Collector breakdown voltage is 390V not 24V, and I was wrong, 5V is plenty to drive this IGBT, it's designed for driving ignition coils so I would say its perfect for this application.
Tue Aug 11 2009, 05:44PM
The IGBT's are usually not avalanche rated, which mean they'll blow up if you exceed the breakdown voltage. MOSFETs, on the other hand, just clamp the voltage like a zener diode and dissipate it as a heat.
But I think I see a SERIOUS problem with the schematic, the circuit puts only 5 volts to the gate?! This is by far not enough to turn on an IGBT. 10V is absolute minimum, 15V is preferred. 5V probably just puts it in linear mode so it doesn't switch much power and gets hot.
CT2
Tue Aug 11 2009, 07:20PM
I also thought the same thing Dr.Kilovolt, but if you check the datasheet for that IGBT, page 4 figure 8, the graph doesn't even go to 5 volts. At 2.5 volts on the gate your Ic is already at 10, and I don't even think you can push that much through the iggy with this driver, so although it seems strange 5volts is fine.
cduma
Wed Aug 12 2009, 09:02PM
Why do you want to drive it with an NE555? You can achieve the same result with 2 3055 transistors and some passive stuff.
Wed Aug 12 2009, 10:17PM
cduma wrote ...
I don't think so...
