  • Guests: 75
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/27 muller (38)
01/27 Dr. Mario (38)
01/27 Ben Solon (30)
Wierd Coil Gun problem
EvilTesla-RG
Sat Jul 18 2009, 08:35PM Print
EvilTesla-RG Registered Member #1523 Joined: Sat Jun 07 2008, 02:05PM
I am continueing to work on mt first coil gun.
But i have yet again ran into an interesting problem.
I have built my capacitor bank, charging circuit, coil and physical switch.
I then tuned my coil to my capacitor bank, all with the switch.
So far, exept for some charging circuit issues, everthing was working better than fine. (Putting large dents in putty)
NOW however, I have swtiched from a physical switch, to an SCR.
This is the ONLY change I have made, and yet, now, the coil wont fire.
I have a voltmeter hooked up, and I can charge up to my target voltage (270), I then hit the trigger to activiate the SCR. Which discharges the capacitors through the coil.
I see the voltage drop from 270 to .9 volts.
AND YET
it does not fire the projectile. (a BB)
I find it strange that by switching switches, my gun is no longer opperational.
Has anyone any ideas? or better yet, has anyone encountered this before?
Thanks
EvilTesla
Saz43
Mon Jul 20 2009, 03:10PM
This problem is usually due to projectile position. Try starting your BB at a different distance from the center of the coil.
PYLEMET-mk2
Wed Jul 22 2009, 09:40PM
PYLEMET-mk2 Registered Member #1513 Joined: Sat May 31 2008, 12:08PM
BB is not good projectile, use nails
Thu Jul 23 2009, 05:32AM
The reason a BB is not a good projectile is that best performance occurs when the coil is about the same length as the projectile. There are huge practical problems designing a coilgun with a coil that's only a few mm long.
By using a 1" nail, for example, you can build a 1" coil and it will have a much greater chance of working well.
Cheers, Barry
Forecast for tonight is alcohol, low standards and seriously impaired judgment.
Dr. Resonance
Sat Nov 07 2009, 11:26PM
Dr. Resonance Registered Member #1670 Joined: Mon Sept 01 2008, 08:32AM
just an idea, but the mass and the overall area of the BB may be so low the magnetic field has nothing to "grab" and accelerate. I use a cylinder type projectile which is longer than the dia so the mag field can grab it and accelerate it.
Dr. Resonance
Caduscus
Tue Nov 10 2009, 02:28AM
Caduscus Registered Member #2388 Joined: Fri Sept 25 2009, 12:17AM
nothing burning? the power has to go somewhere right? turn out the lights and check for arcing
cduma
Mon Dec 14 2009, 03:04AM
My guess would be that the SCR is either not fast enough or not turning on all the way. I would probably guess a little of both. If you have an O-Scope I would check and see if there is an RF spike when you pull the trigger or just listen for a POP on the stereo.
Mon Dec 14 2009, 03:32AM
He's given us two different clues here that mostly seem to have been ignored.
It worked with a light switch, but doesn't now (with the same projectile).
The voltage drops, so the power is going somewhere.
I have a couple theories, but need a little more info. Can you sketch up a quick schematic of your circuit? Is there a protection diode in the circuit? Also, do you know the part number of your SCR? Its possible that you aren't switching it on in quite the right way for that particular device. Its unlikely that the SCR is 'too slow', as it doesn't really have a conducting state below maximum like a FET does. It also is likely MUCH faster than an average mechanical switch when you factor in several hundred microseconds of mechanical bounce.
-Dave
