  • Guests: 53
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Mazilli
Mon Jul 13 2009, 06:44AM Print
All,
For a plasma globe project, I would like to use a Mazilli oscillator as driver of a B&W television flyback transformer.
Expertise tells me, that I must use around 5-20kHz into it for best results, but the Mazilli's that I have built resonate in the 60-90kHz range.
What determines the resonant frequency of a Mazilli?
I have found that by opening the core up a bit, thus lowering the inductance of the primary, the frequency goes up, so this seems to indicate that it is the primary inductance which determines the resonant frequency. Together with the capacitor across the primary. Is this right?
Also, can a flyback be driven below or under it's own resonant frequency?
Cheers, Finn Hammer
Mon Jul 13 2009, 08:44AM
I would not use the "zvs" driver for a plasma globe for two reasons:
1) the output current available is huge, you'll get big burns when you touch the globe.
2) this circuit inherently needs large amounts of reactive power circulating between the cap and core EVEN when the output is not loaded. This leads to high losses in the core and primary, which WILL get hot after some minutes.
Mon Jul 13 2009, 01:02PM
fo= 1/sq. rt. LC
Mon Jul 13 2009, 03:56PM
To echo what Harry said, the resonant frequiency is determined by the primary inductance and the resonant capacitor (the dc block inductor should not change the resonant freequiency). However, you must keep in mind that the primary is coupeled to the secondary, and the secondary's self capacitance--which is why the circuit likes to kind of lock onto a certain frequiency. With a commercial flyback you can't really change that, so your best bet is to use a large primary capacitor (I have heard as high as 10ufd being needed!) And living with the large circulating currents in the primary that will result.
One final note-do make sure that you have some way to limit the output current, the output of a circuit like this is quite lethal.
