  • Guests: 42
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
modifying three phase output of generator
Wed Jul 08 2009, 04:18AM Print
I was hoping I could get a theoretical answer before I do a field experiment. I have a three phase generator connected in a Star configuration. The three outputs are rectified and smoothed with a capacitor. The DC voltage output is 1.4 * 1.7 * ACsinglephase, where the 1.4 is from converting ACrms to DCpeak.
What would happen to the total output wattage if I rectified and filtered each phase separately, and then connected them in series? The voltage would be 1.4 * 3 * ACsinglephase. However, I don't know what would happen to the current.
Carbon_Rod
Wed Jul 08 2009, 06:39AM
=P
Wed Jul 08 2009, 04:12PM
It is a nice summary of rectification, but it does not answer the question of what happens when the phases are connected as *separate* DC supplies with their own individual rectifiers and smoothing capacitor. The wiki articles shows normal 6-diode bridge rectification.
Wed Jul 08 2009, 05:47PM
By conservation of energy, the current will be less by a factor of sqrt(3), since the voltage is greater by a factor of sqrt(3).
Wed Jul 08 2009, 06:47PM
For rectifier/capacitor the result will be the same overall VA.
i.e. (1/3 Current) x (3x Voltage)
The ripple voltage will also be x3
That's my prediction.
stop4stuff
Wed Jul 08 2009, 11:25PM
stop4stuff Registered Member #64 Joined: Thu Feb 09 2006, 06:25AM
you might find some of these useful
Star, Delta, and Jerry Rig Ohms
'Jerry Rigged' ins and outs
Star Delta Jerry
Delta, Star, Jerry rigged?
...and where it all started from...
Jerry's new dual rotor wind test
Thu Jul 09 2009, 04:12AM
StopStuff,
This is why I had asked the question. I was actually reading about Jerry's modifications and wanted to get a perspective from this board. Thank you, anyway.
