  • Guests: 40
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Mystery component identification
ragnar
Wed Jul 01 2009, 08:03AM Print
Hi team,
I want to identify what these components are: the black ones with the blue arrows around the top. They don't measure a diode drop in either direction.
I'm guessing the board was from some kind of flashlamp or starter; the transformer (iron) has a tap coming out to the orange capacitor to the middle of two of the black things in series.
I'm not sure if the orange cap is supposed to resonate with the transformer secondary.
I'm not sure if the grey C, black D and carbon R in the middle of the board are an RCD snubber. If they were, what are they protecting; the spark gap?
If anyone has a better understanding of what this is or how it works, please feel free to offer your explanations!
Cheers, M
1246435399 63 FT0 Hv2
1246435399 63 FT0 Hv1
Wed Jul 01 2009, 08:23AM
Is it a fluorescent lamp starter-control circuit of some kind?
Wed Jul 01 2009, 08:49AM
Maybe could be a HID lamp ignitor?
ragnar
Wed Jul 01 2009, 09:08AM
I think it was an arc-lamp igniter, but I have two different versions; one which doesn't have the orange capacitor and the black things.
I've found this datasheet: http://www.warnerpower.com/pdf/150400%20Specs.pdf - but it says nothing about the little black things with the blue arrows along the top. wink
I can't think why the capacitor would be added in there, it doesn't strike me as a quasi-resonant anything.
Electroholic
Wed Jul 01 2009, 09:28AM
by"no diode drop in either direction" do you mean a short? or do then seem open? Sometimes HV diodes have too high a Vfd to be measured directly.
It looks like a CW doubler, feeding the doorknob cap?
The whole thing seems to be an HID ignitor, the black thing at the top seems to be the inline pulse transformer.
and im guessing the white thing is a sparkgap of some sort.
Wed Jul 01 2009, 09:43AM
I will go for the HID lamp starter, with the doorknob as igniter capacitor. Perhaps from a projection system of some sort?
Wed Jul 01 2009, 01:08PM
they are just high voltage diodes. The blue arrows denote cathode.
ragnar
Wed Jul 01 2009, 01:28PM
Thanks guys and EVR, your ideas are consistent with my experience of HV diodes having very high (eg 10V - 70V etc) drops, making them hard to test, and weird packages (varying from no markings at all, to printed ratings and no part#).
Since the datasheet specs 300Hz, I can probably replace these with microwave oven diodes.
Cheers, solved!
mikeselectricstuff
Wed Jul 01 2009, 11:17PM
In an igniter type circuit they could be sidacs, used to dump a capacitor suddenly into a transformer primary to generate a striking impulse. Draw out the schematic and it should be more apparent what they are supposed to do.
MinorityCarrier
Thu Jul 02 2009, 12:27AM
It looks like a two-diode CW circuit.
It also looks somewhat similar to a trigger circuit for firing off a Xenon arc lamp that I had once (may still).
The Xe lamp ran continuously at a nominal 150 W, (~22 VDC arc), but took ~10KV to start. A big HV blocking diode was between the lamp supply and the HV trigger supply/ lamp.
