  • Guests: 81
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Question about Motion Detectors
teslaguy
Mon Jun 29 2009, 06:26AM Print
teslaguy Registered Member #617 Joined: Fri Mar 30 2007, 07:29PM
I am working on a project which involves passing a an object about the size of a soccer ball through a 36" hoop. I considered using a diode or laser and a photoresistor to detect movement but the balls motion is only detected when it passes through the hoops center. So my question is does anyone know of a better way to detect motion? One day I would also like to be able to detect the velocity of the object passing through the hoop but thats not a project for today. I need to build six of these devices so I would appreciate inexpensive ideas but all are welcome. thank you.
big5824
Mon Jun 29 2009, 07:02AM
Either use multiple laser and photodiode pairs, or try and use mirrors to reflect the laser into a grid like pattern across the hole.
Mon Jun 29 2009, 08:21AM
How about a pyroelectric sensor as used in most other motion detectors?
In England, it's usually much cheaper to buy a retail unit, and take the guts out, rather than buy parts/sub-assemblies individually.
I see there's a DIY pyroelectric motion detector here, and you will doubtless find more if you look:
Pyroelectric Infrared Motion Detector, PSoC Style
Ultrasonic transducer pairs for Doppler motion detector burglar alarms are also available at bargain-basement prices, (because they are no longer in fashion,) but a lot more tricky to set up than disemboweling a cheap PIR unit which already comes with a Fresnel lens.
MinorityCarrier
Mon Jun 29 2009, 03:25PM
Pyroelectric might work if there is a detectable thermal delta associated with the moving ball.
I'd suggest ultrasonic ranging if the ball surface is fairly acoustically reflective.
Extreme Electronics
Mon Jun 29 2009, 08:18PM
Extreme Electronics Registered Member #74 Joined: Thu Feb 09 2006, 09:17AM
But much easier to get good velocity information from. If you can get an old ultrasonic Alarm board or hack up a reversing parking aid, you can get a proximity output. The Rate of change of this output gives you velocity.
Derek
