  • Guests: 42
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Capacitor in voltage multiplier
lhl_henrylui
Wed Jun 24 2009, 01:13AM Print
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
I am going to make a voltage doubler by 10uf electrolytic capacitors.Can I connect two 20uF electrolytic caps oppositely series?
Turkey9
Wed Jun 24 2009, 02:46AM
It all depends on how they are then connected to the rest of the circuit. Plenty of voltage multipliers have been made with electrolytics of your size. The caps will be fine as long as the voltage across the individual caps is the correct polarity. A schematic would also be helpful.
Wed Jun 24 2009, 07:02AM
Most voltage doublers can use electrolytics singly,
IF you need non-polarised consider 'lighting capacitors'
available from a few uF to 10's of uF quite cheaply (eBay)
they are film capacitors designed to be operated across the mains
and are very reliable.
lhl_henrylui
Wed Jun 24 2009, 11:32PM
Capacitors in voltage doubler can be polarised?I am afraid that it will explode.
I can't buy anything on Ebay because I don't have a credit card.I just want to know whether my method will work.
Turkey9
Thu Jun 25 2009, 12:34AM
Non-polarized means that it can have a voltage of either polarity on it; there aren't any negative or positive leads. You mighty want to do some more research on this if you're building this to charge a coilgun bank... that can be some serious voltage and it gets hugely dangerous if you don't completely know what you're doing.
Dr. Slack
Thu Jun 25 2009, 11:15AM
Capacitors in voltage doubler can be non-polarised?I am afraid that it will explode
Depending on your configuration, the first capacitor must be non-polarised, the rest can be polarised.
It may help to get a circuit simulator (suggestions on the wiki, I prefer simmetrix), and look at the voltages on the various capacitors versus time. Simulator is less likely to explode than real life.
lhl_henrylui
Thu Jun 25 2009, 04:20PM
Sorry,I've got a mistake.I typed "polarised" as "non-polarised".Now I've corrected.
Wed Jul 01 2009, 03:23PM
It should work just fine to use 2 capacitors 'back to back', however you should add a reverse diode on each capacitor to prevent them from being reverse charged.
big5824
Wed Jul 01 2009, 03:28PM
afaik the first stage of the multiplier cannot be polarised caps, but after that the voltage is rectified so electrolytics can be used.
Bonehead
Wed Jul 01 2009, 05:47PM
Bonehead Registered Member #2046 Joined: Sun Mar 22 2009, 01:12PM
Check under construction->Voltage Charging-Tripler. Polarized ones used there and works.
