  • Guests: 58
rectifying high amps
Omicron
Sun Apr 09 2006, 02:10PM Print
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
How would you rectify high amps? I am getting a transformer that gives out 24 volts at ten amps. It would be hard to use diodes for some thing like that because of the high current. Google was no help.
http://www.google.com/search?hl=en&lr=&q=recifying+high+amps
I will be using this for a power supplie for a ZVS driver.
Heres the trasformer, http://www.mpja.com/productview.asp?product=7846+TR]
ragnar
Sun Apr 09 2006, 02:16PM
I think you'll find "diodes" are exactly what you want. Go grab a bridge! My local electronics store sells 2A, 4A, 15A and 36A bridge rectifiers, the largest < $5.00
Google was probably no help because A) you didn't spell 'RECTIFY' with a 'T', and nobody really talks of 'high amps', rather, CURRENT.
If you can't buy a suitable bridge rectifier, have you got some stud diodes lying around? How about parallelling 1N4007s, if the parts you have access to is limited...?
Marko
Sun Apr 09 2006, 02:22PM
You can dig out some dual diodes from dead ATX SMPS's (rated about 50V and 30A).
They have somewhat bigger voltage drop than ordinary diodes, and I dont think one should have too much trouble with buying couple of strong diodes or bridge rectifier.
Omicron
Sun Apr 09 2006, 02:27PM
Thanks, I will get some bridge diodes.
Dr. Shark
Sun Apr 09 2006, 02:31PM
Firkragg wrote ...
Whoops, they are Schottky diodes, so they have a lower voltage drop. Guess that was what you meant to say.
Sun Apr 09 2006, 05:03PM
You are forgetting the first rule of semiconductors. Remember, that with semiconductors, current is "Free" and you pay for voltage. Just look harder.
I have diodes in my workshop rated for 1000A ! Look and ye shall find.
Marko
Sun Apr 09 2006, 06:32PM
Yep, thanks for correcting me ill
Schottkys from ATX'es usually measure 100-200 milivolts but that increases with current (datasheets usually say 500 or more milivolts at 15 amps).
Sun Apr 09 2006, 07:17PM
Registered Member #256 Joined:
if you have an old dc arc welder lying around then there you go, i mean if you do a little bit of searching you will be able to find something, as EVR said, he has a 1000 amp diode, i would like to see a picture of that there!!!
Marko
Sun Apr 09 2006, 07:36PM
Large puck or stud diodes can easily handle hundreds and thousands amperes continuous.
I dont remember seeing arc welder with rectified output, except my proffesor once built in bridge of strong stud diodes. He claims that DC arc is more stable and 'smoother' than AC, thats obivously welder's job.
Sun Apr 09 2006, 08:52PM
I'd just use a Bridge Rectifier
for 24Vac I'd use 50V or more rated bridge
10 Aac is equivalent to 6.2A dc due to 'lumpy' current waveform
so a 7A dc Bridge Rectifier will do.
DON'T go for a high voltage Bridge.
as the forward (on) voltage of diodes increases
with increasing voltage rating (in general)
DO go for the highest current rating you can.
a 35A bridge operating at 7A will drop less voltage than
a 7A bridge operating at 7A (in general)
IF you can get four 50V 10A schottky diodes you will gain about 1V dc.
