  • Guests: 39
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
555 "Stopwatch"
Arkin
Sun Jun 14 2009, 01:23AM Print
Arkin Registered Member #2140 Joined: Tue May 26 2009, 09:16PM
So i got a counter today, and i wanted to make basically a stopwatch as a chrono graph. It works at 10kHz, so it is plenty accurate. I am trying to think of a way of basically activate an IGBT when a photogate is triggered, keep it on, and turn it off when the second photogate is activated.
When the photogate is activated, a voltage is given out, very briefly (while it is blocked). Is there a way i can go about this using only 555's (all i have now)?
twist2b
Sun Jun 14 2009, 02:19AM
twist2b Registered Member #2086 Joined: Tue Apr 21 2009, 02:33AM
Z28Fistergod
Sun Jun 14 2009, 12:18PM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
You can set the 555 up as a monostable timer, connect the photo sensor signal to the trigger pin of the 555, and then connect the second photo sensor to the reset pin on the 555. As long as the timing cycle is longer than the time it takes your projectile to move from the first sensor to the second you are set, you can use an arbitrarily large value since you wont actually be letting the timer reset on it's own.
big5824
Sun Jun 14 2009, 01:27PM
a D-type flip flop would do the job too, and will probably be easier. Just pull D high, then connect the first sensor to the clock, and the second sensor to reset.
Arkin
Sun Jun 14 2009, 05:54PM
Thats exactly what i was looking for, forgot about the reset pin =p.
Z28Fistergod
Sun Jun 14 2009, 06:27PM
Or a toggle flip-flop with a diode OR gate at the input (if required). Although the 555 has the advantage of "timing out" in case of a triggering error with the second photo sensor.
Mon Jun 15 2009, 12:23AM
Here is a photogate controller i designed awhile back.
See attached PDFs.
]photocontroller_sheet01.pdf[/file]
]photocontroller_sheet02.pdf[/file]
]photocontroller_sheet03.pdf[/file]
