  • Guests: 50
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
First Coilgun
jaysun92
Fri Jun 12 2009, 02:56PM Print
jaysun92 Registered Member #2114 Joined: Fri May 08 2009, 11:58AM
here are some pictures of my first coilgunhttp://img3.imageshack.us/gal.php?g=img3514f.jpg
it can shoot the projectile about 10 feet but i am going to add more capacitors to it soon
tell me what you think of it
Pylon
Tue Jun 23 2009, 12:24AM
Pylon Registered Member #2065 Joined: Sun Apr 05 2009, 06:32PM
Tape inside looks terribly. Say something about capacitors. I guess that you use photoflash capacitors.
Z28Fistergod
Tue Jun 23 2009, 01:00AM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
I'm a fan of the structural duct tape, and good use for an old timing light.
Bonehead
Tue Jun 23 2009, 06:18AM
Bonehead Registered Member #2046 Joined: Sun Mar 22 2009, 01:12PM
You sure like tape. More specs would be interesting?
Saz43
Wed Jun 24 2009, 11:04PM
Not bad! My first coilgun was made out of trash and a disposable camera.
jaysun92
Thu Jun 25 2009, 12:10AM
It has a capacitor bank of 1260uf 330v photoflash capacitors now
Killa-X
Thu Jun 25 2009, 12:23AM
jaysun92 wrote ...
You can never have too many cheesey That's roughly 68.607J. I'm going to estimate that's around 10 camera capacitors? Isn't a bad design, I hand-crafted a pistol out of sheet metal at Home Depot in the ducting area (8X11") and used glue. I also used camera capacitors, Later got 76.7J (400V 470uf) ones.. 10 of them, And now I have a 200J photoflash bank. Over 60 in parallel :)
Be happy to see more pictures....power source...etc.. I use to use 4AA (parallel) and 8 mini-camera circuits in parallel. It speeds it up A LOT
PLEASE CHECK YOUR BOARD IS AS HE SAYS. You NEED the Diode, Transistor, and LED in the same corner. If you have spare circuits, i recommend this. You create less resistance and it charges over 3X faster. If you can manage to do the hack, Please do it!
And with this one, It involves taking it all apart and .. yeah.
JUST MAKE SURE IT'S A "FIVE" PIN TRANSFORMER FIRST! Thanks cheesey
jaysun92
Thu Jun 25 2009, 07:15PM
i use 2AA bateries in paralell to charge it.
but my charging circut died so i have to make a new one
