  • Guests: 50
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Argon laser - how to run it?
c4r0
Fri Jun 12 2009, 10:24AM Print
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
Hello! I just received a used argon laser that I've bought on ebay cheesey According to the 'danger' stickers, max power is (was) 160mW CW @ 450-515nm. Running time counter says 45kh, but the laser was remanufactured at 31kh. I paid for it 70GBP so I'll be happy if it lase at all tongue This is how it looks like.
1244800755 151 FT0 Img 2192 Resize 1244800755 151 FT0 Img 2193 Resize 1244800755 151 FT0 Img 2194 Resize 1244801296 151 FT0 Img 2197x Resize 1244801296 151 FT0 Img 2205x Resize 1244800755 151 FT0 Img 2198 Resize 1244800755 151 FT0 Img 2199 Resize 1244800755 151 FT0 Img 2201 Resize 1244800755 151 FT0 Img 2202 Resize
Looks like there is some beam splitter with a power sensor on the last photo. And is that black box with white 'danger: laser radiation' sticker (on the same photo) an ignition circuit? There are three wires going to this box: two thick, one of them goes to the anode and the other to the plug, and one thin black wire that is probably a ground.
Do you guys have any idea how to run it? I know that it takes a few amps (at least it should start lasing at this current) on the tube and voltage drop is around 100V. But I have absolutely no idea what is the filament current :/ Member kilovolt, I think you will have something to tell since you have successfully made a PSU by yourself :) I have a JDSU argon laser PSU and if possible I would like to use it with this laser:
1244800869 151 FT0 Img 1380 Resize 1244800869 151 FT0 Img 1381 Resize 1244800869 151 FT0 Img 1382 Resize
c4r0
Fri Jun 12 2009, 02:32PM
It works!!! amazed Filament seems to run OK at 3,5V 28A. The laser lights quite nice at almost 4A. I dont know why current regulation in my power supply doesn't work. I was checking it with 2kW electric kettle as a load, the power supply gives 7A no matter what current is set by a pot. Any idea what's going on? I don't know if the PSU is broken or I just don't know how to use it properly. There is always 0V at the current monitor output of the PSU, so I think that current measure circuit inside the PSU may be broken. But anyway, I connected the laser tube in series with that kettle and it works, so I'm happy :D
1244817881 151 FT71310 Img 2217x
Fri Jun 12 2009, 02:36PM
That's brilliant! I'm really pleased for you! You must tell us all about how you get on with it, what experiments you perform...
Harry.
Wolfram
Sat Jun 13 2009, 01:41PM
The JDSU supplies usually have a constant optical power mode and a constant current mode, selected by a pin on the control connector. If it is in constant optical power mode, without the output power sensor in the laser head connected, I bet the power control would act strange.
Anders M.
c4r0
Sat Jun 13 2009, 04:26PM
Thanks for your replies smile The problem is solved! I took the PSU apart and then put it back together, now it works good. Sometimes such things happens with old equipment that has not been used for a long time tongue If you are interesterd, this is what it has inside:
1244910397 151 FT71310 Img 2253x
Sat Jun 13 2009, 08:34PM
That's interesting - what do the two boards at the top of the picture do?
twist2b
Sun Jun 14 2009, 02:24AM
twist2b Registered Member #2086 Joined: Tue Apr 21 2009, 02:33AM
It's pretty neat, what kind of projects are you hoping to use this with? I would love one..... or two :P
Congrats.
c4r0
Sun Jun 14 2009, 02:30PM
Well, I have no idea what to do with it, just another toy in my collection tongue
Harry wrote ...
I don't know. These PSUs have a lot of functions, i.e. current ans optical power stabilization just like Anders M. wrote, so there's a lot of analog signal electronics. Theres also a control panel (actually the real control panel should be connected to that DB25 but I don't have it) that I forgot to place with other boards when taking a photo:
1244988946 151 FT71310 Img 1297 Resize 1244988946 151 FT71310 Img 1296 Resize
OK, I guess that you would like to see some beams :D So here are some photos:
1244989446 151 FT71310 Img 2296x 1244989446 151 FT71310 Img 2299m 1244989446 151 FT71310 Img 2327x 1244989446 151 FT71310 Img 2353x
Here with 100mW DPSS module:
1244989446 151 FT71310 Img 2341xx 1244989351 151 FT71310 100mw 532
Video on YT: Link2
Sun Jun 14 2009, 02:32PM
Cool!
lpfthings
Mon Jul 06 2009, 08:43AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
The boards at the top are most likely control boards. Most argon lasers have an adjustable output, along with many interlocks and warmup features, and it's best to have that insulated from the rest of the circuitry, as the startup pulse for argon lasers are in the kV's.
I am thinking about buying a little NEC GLG3030 ArIon laser, does about 30mw @ 488nm.
I saw your vids on youtube, pretty nice "little" laser :)
