  • Guests: 62
plazmatron (48)
rm203tech (17)
Duality (16)
Jiffycoil (65)
Dandrion (69)
12/20 plazmatron (48)
12/20 rm203tech (17)
12/20 Duality (16)
got an idea on how to connect marxes?
teravolt
Sat Apr 08 2006, 10:48PM Print
I have made a 500kv each marx pair and I am looking to connect them to gether. Now the easy way would be to stack them for a megavolt but I want to sync them and shoot a horizontal spark. I have been to "I want my high voltage and I want it now" and he has some good idias. what do you think.
1144536538 195 FT0 Marx Pictures 2
Desmogod
Sun Apr 09 2006, 02:37AM
I believe mike from mikes electric stuff did something similiar.
He charged one to 500,000V, then the other in negative to give a megavolt discharge.
Sun Apr 09 2006, 03:07AM
I remember a page where someone pointed their N2 laser at the bottom spark gap to make it fire...
Perhapse some type of inductive kick in series with the charging circuit that will fire them?
Desmogod
Sun Apr 09 2006, 03:53AM
The one to beat:P
Sun Apr 09 2006, 03:34PM
Wow, excellent work teravolt! shades
What you need to do is charge one tower positively, the other negatively, and arrange them so they both fire at once. That's what Mike Harrison did, and the page linked by Dr. Desmo has a schematic showing how to wire the two towers together.
teravolt
Mon Apr 10 2006, 12:42AM
Ok dual power suppies sound good. more to rig up but can do. Thanks
Mon Apr 10 2006, 10:08AM
You don't need dual power supplies. Mike uses a single positive supply with paralleled flybacks just like yours.
Mon Apr 10 2006, 03:51PM
Nice marx gen teravolt.
ArcLight
Mon Apr 10 2006, 05:21PM
ArcLight Registered Member #341 Joined: Thu Mar 23 2006, 07:41PM
That's a very impressive machine. I look forward to seeing photos of the pair working together.
mikeselectricstuff
Mon Apr 10 2006, 10:35PM
Bipolar is definitaly the way to go, as it significantly reduces corona losses when firing.
One thing I have observed is that EMP type effects are a lot worse, but I don't know if this is particularly due to the bipolar arrangement, the larger loop area or the higher impulse current. You really don't want multiple supplies, as a misfire could shove a very nasty transient down one fo the supplies...
I have tried an end-to-end stack but this didn't work well, however this was before I replaced all the resistors with solid-carbon, and it may have suffered from some bad ones. Another issue was structural - the only way I could do it mechanically was to have the second stage at right-angles. Given a venue with sufficient roof height and some way to support it I may try a 1MV unipolar vertical arrangement sometime.
