  • Guests: 46
Uses for ultrafast Maxwell pulse caps?
Dr. Shark
Mon Mar 06 2006, 11:54AM Print
Every once in a while you see these white plastic block Maxwell capacitors with ratings like 40kV 80nF and rediculously low ESL for sale on eBay. I know that people use these as tank caps for tesla coils, but I was wondering if there are any other hobbyist uses for these?
More to the point, I was pondering the use of these for electromagnetic projectile accelerators. Even though these capacitors don't store a lot of energy (64J in the above example), the efficiency could be way beyond what is achievable by conventional means, since the incredibly short discharge times (in the ns range?) would make for insane magnetic fields. I like scaling things down, and since I can't work on my 15kJ EM-gun for the time being....
Another thing that came to my mind was a plasma pinch device for some nuclear play. There is a pdf somewhere out there Link2 describing a hobbyist device of that kind. Irradiating things with neutrons could be big fun! Introducing f-center crystal defects, getting stuff to glow in the dark, endless posibilities. Suitable vacuum pumps can also be had for less than 200€.
Would it be stupid spending money on a cap of this type with these things in mind, or would it actually be suitable for these experiments?
G^3
Mon Mar 06 2006, 05:56PM
G^3 Registered Member #97 Joined: Thu Feb 09 2006, 05:40PM
I don't think that one of those capacitors has anywhere near the energy for a plasma pinch device. The smallest plasma pinch devices have use around 2KJ to produce neutrons. I am not sure what you could do with one of those, but if you bought a lot you could make a ridicoulous marx generator.
Dr. Shark
Mon Mar 06 2006, 07:11PM
I have seen Marx generators made of exactly those caps desribed in the literature, and they were used for some serious relativistic electron beam stuff. But thanks, I don't feel like spending 1000s of bucks on capacitors.
But the point is a valid one, what is the minimum energy required for this pinch stuff? I think I read somewhere that the detonators in nukes work by exploding foil detonators which are doing this z-pinch thing aswell. I don't know if this is true, but it would certainly be below the kJ energy range.
G^3
Tue Mar 07 2006, 01:10AM
Nuclear weapons use a exploding bridgewire detonator (EBW.) One of those capacitors looks like it would have more than enough energy available for an EBW. More info on EBWs here
Other than a tesla coil capacitor or for EBW the only thing I can think of is a low pressure nitrogen laser.
Graham
Dr. Shark
Tue Mar 07 2006, 08:58AM
I'm not sure I want to build a detonator, high explosives are illegal in the country so I am not playing with them. A miniature neutron generator would be much more appealing to me!
But if that is out of the question, what about the idea with the miniature, über-efficient ring launcher type of thing? Come on, I need an excuse to buy one of those lovely white caps, and I am sure I cant use it as a tank cap for a DRSSTC!
Plasmaniac
Tue Mar 07 2006, 12:12PM
Plasmaniac Registered Member #206 Joined: Sat Feb 18 2006, 03:17PM
What about a big nitrogen laser?
Dr. Shark
Tue Mar 07 2006, 01:29PM
Maybe not nitrogen, but I think a lot of various gas lasers can be excited in that way. Oxygen, various metal vapours... Many of these work superradiantly, but still a lot of work.
Omicron
Tue Apr 11 2006, 01:32AM
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
What about a barrel crusher? not just a can crusher but a barrel crusher... heheheh
Michael W.
Tue Apr 11 2006, 03:18AM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
For can crushing etc. a large amount of joules are needed...
teravolt
Wed Apr 12 2006, 02:16AM
they would probly work good on a SGT
