  • Guests: 35
Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
12/18 LD LANGER (38)
PCB design - Noise on Flyback driver
tobias
Tue Jun 09 2009, 02:49PM Print
tobias Registered Member #1956 Joined: Wed Feb 04 2009, 01:22PM
Hello all
I'm designing a new PCB for my plasma speaker. The idea is to get out all the noise that was heard on the first design.
Before etching the board I want to show my work and if there's any idea to improve my design I'll glad to read it and to try it.
Sorry for my bad English in advance. I do what I can! =)
First of all a little description of the first design and the 'noise problem' that I had:
- Only one power source for the entire board (+32 V). A 7812 was used to create 12 V to the logical section.
- Ground plane on the entire board, even on the HV side.
- A opamp as 'voltage follower' to give high impedance to the audio in.
- The arc does not make ANY noise when the opamp is not mounted on the board.
- Connecting the opamp a bzzz can be heard. Loud enough to ruin my so dreamed "crystal sound"...
- With a scope I measured the frequency and amplitude of the noise on the out pin of the opamp. It was 120 kHz (the same as my switching frequency) and a few mV Vpp.
So what I already done to improve the design (see picture above):
- Ground plane only on the "12 V" logical section
- Separated power sources for the logical (15V unregulated) and HV (up to 50 V) sections
- Wider traces on the HV side.
- Two RC filters:
- Between the opamp and the TL494
- On the +Vcc of the opamp
- And now the opamp is a gain 2 amplifier.
- The four resonant caps are on the board
- The IRF540 will be soldered on the copper side of the board, having a massive heat sink. That's why it's mirrored.
So.. Any ideas how to improve this design? (schematic and layout)
If anyone wants to see the schematic I can post it too.
Best regards
Tobias
Plasma V2
Andri
Tue Jun 09 2009, 08:34PM
Andri Registered Member #1533 Joined: Wed Jun 11 2008, 02:13PM
Where is the schematic?
Tue Jun 09 2009, 09:34PM
The board looks better, a few things you could try:
* add a 10r resistor between the opamp supply rails and the high power section (in your design that would only be the ground). This will help cut back on the noise that creeps in, forming a rc filter with the filter capacitance on the opamp
* add extra filter capacitance right next to the opamp .1ufd ceramic would do fine
* add a 100r resistor from the input to the filtered opamp ground (sound cards are designed to feed into a 30r or so load, so feeing them into an open circuit just lets more noise in)
*leave some space around the opamp + power circuitry so that if you need to you can add on a 'doghouse' or metal shield (pieces of unetched copper clad work well for making these).
good luck!
twist2b
Tue Jun 09 2009, 10:38PM
twist2b Registered Member #2086 Joined: Tue Apr 21 2009, 02:33AM
I have a noise issue as well.... well not really, the output on my flyback just sucks.... the gap can only be like 1/4th an inch (sad) It used to be an inch EASY. I am still figuring out the issue, but yeah, I want to PCB my design as well.
tobias
Wed Jun 10 2009, 01:28AM
Here it is!
Peter. From your list the only thing that I didnt do yet is creating space for the doghouse. Did I misunderstood something? Can you check it out the mods I made if it corresponds with what you told me to do?
The only doubt I have is about the 0.1uF filter cap.. I put it between the Vcc and Gnd of the opamp, after the 10R filter. Is that alright?
With the last modifications, layout and schematic:
1
The schematic got a little messy after the quick modifications that Peter proposed so...
1 Schem
Wed Jun 10 2009, 02:51AM
That looks pretty good, and don't worry about the shielding too much for now, hopefully it won't be an issue with the few changes you made.
Steve Maurer
Wed Jun 10 2009, 04:36AM
Steve Maurer Registered Member #133 Joined: Fri Feb 10 2006, 10:27PM
Hi Tobias,
A few notes to consider:
A double-sided board layout would permit reduction of your loops that may pick up fields from your HV section. Keep your loop areas small and you will reduce some of your noise. If you need to stay with a single-sided board, then I would still try to keep your traces as short as possible and keep your loop areas small.
I would not run any HV ground returns through your low voltage ground plane. Tie all of your HV grounds together, and then run a wide HV ground trace from your HV tie point all the way back to your circuit board input ground. Keep some spacing between this HV ground return trace and your low voltage ground plane, otherwise the HV ground currents may couple to your low voltage ground plane. Tie your HV ground return trace and your low voltage ground plane together only right at the circuit board ground input location. The key is to keep high frequency currents from traveling through your low voltage ground plane and getting into your op-amps.
If you have available room, place more physical space between your HV section and your low voltage section. You want to keep any coupling between the two sections down to a minimum.
Have fun. It looks like an interesting project.
Best regards,
Steve Maurer
TwoSpoons
Wed Jun 10 2009, 05:11AM
TwoSpoons Registered Member #1621 Joined: Tue Aug 05 2008, 05:26AM
What you are currently calling a groundplane isn't - its full of big slots and holes. Go double sided and make one side your ground plane. Do not run tracks through it.
tobias
Wed Jun 10 2009, 10:06AM
Working on it!!
I never done a successful double sided board before. I use the laser print - glossy paper transfer method and I dont have the skills needed to get both sides aligned.. And here in Brazil to pay for a company to prototype the board is too expensive. So... single side would be! =P
I'm creating the return of the HV ground to the board ground input, trying to expand my board and put the ressonant caps on the right of the mosfet (while eagle says "I'm free, I dont do that!"). And trying to get a better arrangement of the components to reduce the loops.
I think I can do that this way: Get my layout etched on a double sided board with one side fully protected. Drill the holes and then circle around them on the ground plane side with a pen. Protect the traces side with tape and etch it again... sounds "doable"?
Thanks for the responses! I will work this morning trying to post the mods again here today.
Best regards, Tobias
Wed Jun 10 2009, 11:53AM
Tobias,
Just a few things:
1. Your ground plane really isn't doing anything or acting as a ground plane. What a ground plane should do is to ensure return currents from signals on the top layer travel directly underneath the currents on the top plane (extremely small loop area and inductance). However, your ground plane is broken up with big islands, etc... So any return current on the bottom plane will be forced to travel in large loops around those traces, etc... Move the traces up to the top layer.
2. Also, if you are resonanting at 120kHz, you are NOT going to get crystal clear sound no matter what you do. You are still going to get harmonics in the arc down into the audio range at that frequency and get a "hiss" sound. It has been proven that you need to be switching at 3MHz+ to get truly clean sound.
3. Finally, the DC power that is feeding your switching circuit is UTMOST CRITICAL to be as clean as possible with no ripple whatsoever. Either have a regulated DC supply with a bandwidth much greater than 20kHz, or provide enough capactiance so that ripple / droop is minimum, otherwise you are going to "hear" it in the arc.
If you want crystal clear sound, scrap this design and build a class-e 4MHz+ coil.
I built one recently and its fabulous. It switches at 4MHz, and the DC supply is regulated as well so the DC feeding the class-e is pristine.
