  • Guests: 38
Photoflash Charger
jaysun92
Tue Jun 09 2009, 11:38AM Print
jaysun92 Registered Member #2114 Joined: Fri May 08 2009, 11:58AM
if i use a photoflash charger can it over charge the capacitors? or will it just increase the voltage to a certain spot and then stop?
Thanks to anyone who helps
Tue Jun 09 2009, 11:51AM
If the capacitor has a suitably high voltage rating - about 350V for most photoflash chargers - then the voltage will rise to a maximum and then stay there. You can't 'overcharge' a capacitor, unless by that you mean apply more voltage to it than it is designed to withstand.
I would guess, though, that the tiny charging transformer and transistor wouldn't like it to be left on for too long at a stretch, as they aren't designed for continuous operation - but you must ask someone who has actually tried this.
rp181
Tue Jun 09 2009, 04:52PM
With a standard power source, these do not get warm, they can operate for a while. You can use 3 volts input for short runs, to achieve a high voltage and faster charge rate.
Saz43
Sat Jun 13 2009, 06:59AM
All of the camera chargers that I've encountered automatically shut of at a certain value. For example, most of the ones I obtained have 330V caps, and the charger shuts off around ~315V. Increasing input power only decreases charge time.
rp181
Sat Jun 13 2009, 04:52PM
The ones I have seen don't shut off, but just light a LED. In one case, I let it charge with a higher voltage supply, so the LED exploded.
jaysun92
Sat Jun 13 2009, 06:09PM
will a D size battery charge faster than a AA battery, and how much faster will it charge?
rp181
Sat Jun 13 2009, 06:23PM
It will not charge faster, but will last longer. More voltage will make it charge faster.
Killa-X
Sat Jun 13 2009, 06:37PM
I prob kill mine yet they still work. I got 7 in parallel, and i cut the board to 1X1cm. They can charge my 100J camera cap bank in maybe 15-30 seconds sadly, but I would expect that for such low power, as they aren't made for this. I think I had like 6 batteries in 3V parallel.
jaysun92
Sat Jun 13 2009, 08:16PM
but if i increase the input voltage wouldent it overcharge the capacitors
