  • Guests: 53
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
2.5W Green Laser Project
Laser Ben
Sun Jun 07 2009, 07:59PM Print
Laser Ben Registered Member #2163 Joined: Sat Jun 06 2009, 10:49PM
Thought I would post some pictures of my latest project. I got a nice 2.5W 532nm medical laser system from a friend. It's an Alcon Eyelase system.
Anyways, it's a 1.6mm x 12mm Nd: YAG rod pumped by a 20W 808nm Diode array. The cavity is a sort of a Z-Fold with an extra mirror. The KTP is 2x2x5mm and is situated within a small heater with a 1M thermistor integrated inside. The overall head temperature is controlled by a 60mm TEC with a 100k thermistor integrated into the head.
Basically, I need a 40A diode driver, which I am getting from another member on here. Other then that, I need a single ended temperature controller using a 1M thermistor that can do small currents. I doubt the heater takes more then an amp. I also need a Heat/Cool controller for a 10A TEC using a 100k thermistor.
Does anyone know where to get a controller for these? I would like something small if possible, but I can go larger if needed.
I also attached the image of the projector design I am planning. The blue is a 250mW 473nm unit from Laser-Wave.
3604053505 19f5a41a5f
1244404584 2163 FT0 Projector Optics Layout
brtaman
Sun Jun 07 2009, 10:00PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
That is some incredible work, I remember seeing it on LPF. Post some beamshots when you finish the beast!
Laser Ben
Sun Jun 07 2009, 10:26PM
Thanks Man!
"..." on this forum has offered to make me a combo TEC/Heater controller for the laser. I am also getting a power supply from another member so I hopefully should have it up and running soon.
brtaman
Sun Jun 07 2009, 10:44PM
That is awesome! Still won't be as cool as the direct injection spectra laser you have, but 2.5w is green is a sight to see! :D
Laser Ben
Mon Jun 08 2009, 02:28AM
I actually just got a second 250mW blue unit. So now my total balance is 2.5W green 0.5W blue ?W red.
c4r0
Mon Jun 08 2009, 07:04PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
Awsome! :D I wonder if the analog controller of my Compass 315M laser would manage to do the termal controll stuff with this laser.
LutzH
Mon Jun 08 2009, 07:54PM
LutzH Registered Member #1721 Joined: Sat Sept 27 2008, 08:44PM
Hello:
Try Lightwave Electronics, they have what you are looking for. Also I saw some by this manufacturer on ebay a short while ago, and they come up a lot, try there also.
Laser Ben
Mon Jun 08 2009, 09:09PM
This is an OEM product for a medical laser. They don't even acknowledge that they ever made it...
Z28Fistergod
Tue Jun 09 2009, 01:11AM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
Laser Ben wrote ...
What's up with that? I ran into the same thing with Coherent, and Inrad. It's like some sort of secret...Shhhh don't tell. I don't know why they even put their name on it.
Laser Ben
Tue Jun 09 2009, 04:51AM
They didn't put their name on it :)
