  • Guests: 60
Elliott (35)
Gratitude (40)
Swraka (37)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
reversed voltage killing charger?
woxxey
Sat Jun 06 2009, 12:38PM Print
woxxey Registered Member #1906 Joined: Sat Jan 03 2009, 05:06PM
Is it possible that the reverse voltage can kill a boost conveter (uzzor model)?
Used a pair of capacitors for the first time, and after firing with 400v and a >1 ohm coil the charger stopped working (only charging to 12v).
If so, what parts is likely in need of replacement?
and would a reverse-paralleled diod fix the problem for the future?
Sat Jun 06 2009, 05:30PM
Reverse voltage from an underdamped LCR discharge can kill most any charger that has just a diode between high voltage source and capacitor bank. Just look at the schematic, and figure what happens when charger output is connected to high voltage of the opposite polarity! Remember the boost converter MOSFET probably has an internal diode that wants to conduct when drain is pulled below ground.
One solution is a mechanical switch to disconnect charger before the impulse discharge.
Another is a series resistor between charger and main capacitor, to limit the current sucked from charger. With a boost converter like Uzzors's you would need a smaller capacitor "before" the resistor, to receive the current pulses from boost inductor. Are you going to be slowed down much if series R times main bank C is a second or two?
TheMerovingian
Fri Jul 03 2009, 12:51PM
You need to clamp the coil with a R-D (resistor-diode) networt and a diode in antiparallel on the capacitors. This because the coil discharges the bank completely and then pulls the voltage negative (overdischarge or reverse charge) this causes the boost converter diode to conduct from ground to the coil (huge currents) and the mosfet as well. This happened to mee too, but since i was using an isolated transformer only the diodes blow (this happened because the R-D network has a failed resistor)
Saz43
Sat Jul 04 2009, 07:13PM
Since the SCR acts as a diode when triggered, how does a reverse charge manage to build up over the capacitor when current can only run from the cap to the coil?
EvilTesla-RG
Sat Jul 04 2009, 09:58PM
EvilTesla-RG Registered Member #1523 Joined: Sat Jun 07 2008, 02:05PM
Becouse the current, after going through the coil, will charge the caps back up again, in the oppisite direction
(LC circuits)
Then doesn't that mean the Diodes should be placed across the Caps???
Sat Jul 04 2009, 11:41PM
The discharge isn't a simple singular event, with electrons going only one way following the polarity signs on the escalator. What you have is a train of damped waves, whose amplitude falls off according to the time constant.
So it could easily be possible that your second 360 degrees could easily put 67% of your initial PD inverted across your polarized capacitors.
(PS. It's very late at night, and my theory looks a bit rough there, but the substance of it still stands)
Sun Jul 05 2009, 12:44AM
Saz43 wrote ...
Draw the voltage and current waveforms. Assuming your LCR circuit loop is underdamped,
the capacitor is fully discharged at approximately the moment of maximum current.
At that point there's no magic reversal of voltage or current at the SCR.
The current continues to run from cap to coil, and the capacitor voltage continues its decline. The increasingly negative voltage on the capacitor now -aids- the circuit resistance to progressively reduce the forward current.
Saz43
Sun Jul 05 2009, 07:43AM
Oh, I see. Thank you for the explanation.
Does it matter, then, if the anti-parallel diode is placed on the coil-side of the SCR or on the cap-side?
The reason I'm asking is because it's much easier to mount the diode directly to the cap leads (it's one of those stud-types).
Thanks! The replies of the people on this forum have been invaluable in allowing my project to continue.
