  • Guests: 50
Inductive Load
Sat Apr 08 2006, 02:52PM Print
I've found what seems to be an inductive load while rummaging through smps's. This one is from a 200 W PSU, but I'm not entirely sure what its for, or if it is an inductive load at all. There seem to be three coils wrapped around the core, one primary and two coils which seem to be shorted. The primary seems to be one turn, or very few turns if any more.
If anyone has any knowledge on how it is actually built up, I'll be glad to hear. The core is a fair sized iron-laminate, so I think I can finally make that mains-xfrmr. I'm thinking of breaking the short on the larger coils and using them as primary and secondary. Any thoughts?
1144507961 95 FT0 Dsc02123
Wolfram
Sat Apr 08 2006, 03:24PM
That is a power factor correction chocke. Computer PSUs are complex loads that only draw current when input voltage is higher than the voltage on the smoothing caps. This gives them a power factor lower than 1, and this inductor helps get the power factor closer to 1. You can read more about power factor here: Link2
Sat Apr 08 2006, 03:52PM
It makes more sense now, thanks Anders. Are these possible to disasemble or should I bother?
Dr. Shark
Sat Apr 08 2006, 06:53PM
I'm surprised you found an iron core inductor in a smps, but if it is on the mains side and does its work at 60Hz, it makes sence. Sure you can use it to make a transfomer, try putting in in boiling water to get off all the goo, and then see how you can get the core apart.
Sun Apr 09 2006, 04:41PM
Boiling water had no effect, and it looks pretty hard to take apart. I want to save the wire too, which sure makes things a lot more difficult.
Would it be possible to wind a primary on the outside of the inductor? How would the flux work then? Otherwise I'll have to cut the inductor somewhere in the middel, and end up with a 1:1 transformer. mad
cjk2
Sun Apr 09 2006, 06:11PM
Well I dont know exactly why, but just looking at the shape of the core I would say you cant wind anything on the outside. You would have to get your wire through the center gap between the 2(?) coils already there.
Mon Apr 10 2006, 08:59AM
I've decided to just make a 1:1 xfrmr, just to make sure things are working like they should. I cut the wire that connects to two coils, and it is now roughly 1:1. So I set it up with a 40W light bulb as a load, and plugged it in. Next thing I know the circuit breaker has tripped.
Am I missing some transformer fundamentals or does it just not like running at 1:1? It is a laminate core, so it should work at 50/60 Hz.
Mon Apr 10 2006, 10:23AM
The volts-per-turn of a transformer is proportional to
the cross-sectional area of the core.
For your transformer there are not enough turns for
direct mains voltage and the core saturates
- making the transformer look like a very low impedance
- which trips the circuit breaker.
You need to operate at lower voltage or more turns
(or higher frequency)
Mon Apr 10 2006, 01:27PM
About how many turns would I need? There seems to be around 100 turns of 18 gauge wire per coil currently.
Marko
Mon Apr 10 2006, 02:18PM
I dont think there is a point to make a 50Hz transformer out of a choke. ž
You have to wind lots of fine turns for primary, and probably there is simply not enough space to put it in, and all for few watts in the end.
Get yourself few small transformers and wire one backwards (if you need low-power isolation transformer) or if you'd like to wind something get one huge core, mot, dead NST etc. and have fun.
