  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Levitating induction heater..
Sun May 31 2009, 08:52AM Print
just found this one on Youtube, seems to work well.
Lots of power required, but the required refrigerator tubing is not too expensive.
-A
Tonskulus
Sun May 31 2009, 10:32AM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
Yes, I have seen that video. Maybe I should try this experiment, I just need new waterpump.. My induction heater has enough power for this anyway. It lifts up some small workpieces easily :)
Sun May 31 2009, 08:32PM
I actually built one of those bucking coils, inspired by that video. The refrigeration tubing is cheap, but wait till you see the cost of the capacitors needed to put 100kVA of RF current through it!
I could get it to levitate, but only with aluminium workpieces, and only with the power turned up as far as it would go, current limiter disabled and so on. What seemed to work best were chainring bolts from a bike: they're lightweight, hollow and made of Al.
I gave up after I got one to melt and drop out of the coil. Since the current limiter was turned off, this caused all my silicon to explode.
Sun May 31 2009, 09:29PM
oops, sorry about that steve.. didn't realise that could happen.
-A
