  • Guests: 66
NST Candle Effects
Omicron
Fri May 29 2009, 10:32PM Print
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
I was playing with my neon sign transformer, noticing magnetic field changes in a xenon bulb when, for no reason, I decided to run the power through a flame, a candle flame. There was instant effects. The flame got incredibly bright and white sparks came off it. In seconds a crumbly black substance appeared on both electrodes, but more where the flame was. One electrode was a pointed piece of iron, the other was a steel “spoon” I had from making fishing lures. I suspect the black stuff is carbon, collected by electrostatic filtering. The flame also moved to the flat electrode, probably by electrostatic wind. Any body else ever see this effect? One more thing, I had let the needle electrode heat up to glowing before I lit the candle.
Voltage: 3000 volts
Current 30 milliamps
Electrode spacing: about 1 cm
Omicron
lpfthings
Sun Jul 05 2009, 06:30AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
I've also noticed this. I would say the flame getting brighter is caused by the arc super heating the wick. The black stuff would just be carbon :)
