  • Guests: 28
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
simple capacitor question
EvilTesla-RG
Thu May 28 2009, 11:44PM Print
EvilTesla-RG Registered Member #1523 Joined: Sat Jun 07 2008, 02:05PM
so, I know that when a single capacitor discharges, the INITIAL resulting amperage is the capacitor's voltage devided by the resistence of the circuit.
I am curious, so does that mean, that no matter how many capacitors (of the same voltage, are connected in series or in parrellel, then the initial amperage will still be teh same? since neither the voltage or resistence changes?
Fraggle
Fri May 29 2009, 12:25AM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
In practice, a capacitor has an `equivalent series resistance` like the internal resistance of a battery, which limits the current.
Bjørn
Fri May 29 2009, 12:32AM
Your model is too simple to give an accurate answer unless your load resistance is quite a lot higher than the internal resistance of the capacitor. For the series circuit the load resistance must be a lot higher than the sum of the ESR of all capacitors.
To get an accurate result in every case you need to model all resistances and inductances of the circuit. Have a look at a more complete model of a capacitor: Link2
So the answer depends on the capacitors and the load.
The largest power delivered to your load is when the ESR equals the the load resistance, assuming that the pulse is so long that the inductance makes no difference.
Fri May 29 2009, 04:50PM
EvilTesla-RG wrote ...
Capacitors are energy storage.
Load current *is* the voltage / impedance.
However, the impedance isn't just the load. Impedance = ESR of the capacitors + Load
So Load current = Vo / (ESR + LoadImpedance)
Neglecting ESR, the initial current will be the same whether you use 1 or 1,000,000 capacitors in parallel.
The difference is that the voltage will droop far slower with more capacitors in parallel than a single capacitor.
For really low impedance loads, then ESR *does* become important and can limit maximum current.
For example, if I have a 10V cap with a 1 ohm ESR and a 1 ohm load, then my peak current is 5A.
However, if I take (10) of those capacitors in parallel, i now have an equivalent 10V capacitance with an ESR of 0.1 ohm. And my peak current
is now about 9A.
EvilTesla-RG
Fri May 29 2009, 10:33PM
ah ha.
okay, thanks. This is what I needed to know.
