  • Guests: 40
Ideas for a Charger for These Capacitors
nerdywarrior
Tue May 26 2009, 01:26AM Print
nerdywarrior Registered Member #2139 Joined: Mon May 25 2009, 07:54AM
Transformers at hand: Flyback transformer from a tv I no longer needed and a 3kv neon transformer from information unlimited.
Capacitors to be charged: ( 7 ) 12,000uf 400V Caps -
Using either the flyback or the neon transformer - or if you have a better idea - please post circuits/advice/tips on a build that should be adequate to charge them up. It doesnt need to charge them super fast - I just need the job to get done
This capacitor bank is for a rail gun project (6.7kj)
rp181
Tue May 26 2009, 01:50AM
neither, use a voltage tripler, running of mains (in
US)
That is what i use, charges 5.6kJ in under 10 seconds.
hotcrazyfruit
Tue May 26 2009, 02:37AM
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
you do realize those transformers put out tens of kilovolts right? use what RP sent, as using a fly back or NST is running to high a risk to destroy your capacitors .although keep em around, in case you even come by a pulse capacitor XD
Tue May 26 2009, 02:45AM
hotcrazyfruit wrote ...
Yes, but even so, the caps would not die. You just have to watch the voltage. It will be very limited current, so...
Indeed a tripler would work, but you need to use some big current limiting resistors, otherwise you might kill diodes or trip breakers. You can use capacitive limiting, and just use small tripler capacitors though, that will limit the current. Unless i am wrong, of course. Someone else have something to say about it?
nerdywarrior
Tue May 26 2009, 02:56AM
thanks everyone
Myke
Tue May 26 2009, 02:57AM
Use a lamp for resistive ballasting? That seems to be the easiest way to limit the charging current. The lamp will dim as the capacitor charges. There is no need for using a capacitive or inductive ballast in this case because efficiency isn't much of a concern. Also there isn't a whole lot of current coming out of the multiplier so you don't need a huge lamp as far as I know.
Hazmatt_(The Underdog)
Tue May 26 2009, 03:13AM
I'd have to agree with the triplier. That's what I did for my cap charger on my ring toss. Worked perfectly. My resistors get pretty warm, but if you use a lamp on the mains side you'd get the same result. Be prepaired to wait 10 minutes though.
Killa-X
Tue May 26 2009, 04:26AM
Hey. If I wanted to charge a smaller bank say 300J to 400uf... Despte the 15 stages, can I just connect my transformer (26VAC) to a tripler in 15 stages to get 40V to charge my caps? I tested a few camera caps on it to get 80v and it seems to work. I just wonder if I could get a 400v multiplier to charge 400v 300 joules of capacitors. Yet the transformer is rated 400ma, I don't mind the wait. I'm sure it's faster than my 7 camera transformers in parallel which charged 100J in 1 min. On 3AA in parallel
Backyard Skunkworks
Tue May 26 2009, 04:52AM
As I said in the other thread, I'd go for the step up transformer. The tripler, however, is a much easier to build option. You could really use either, but as previously pointed out, stay away from HV sources for cap charging in the real world.
Can't wait to see a video of that railgun, the kinetic energy is going to be crazy if you acheieve even modest efficiency. shades
Z28Fistergod
Tue May 26 2009, 12:10PM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
You don't need any current limiting with this circuit, it is "built in." Like Arcstarter said, the ac reactance of the tripler capacitors will limit the current. The larger the capacitors the more current that is available. 10uF sounds like it would be pretty good for your application, maybe a little bigger but that's just guessing. I would avoid the resistors because they will dissipate a lot of power.
