  • Guests: 47
body charger
Solidacid
Wed May 20 2009, 02:08PM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
hey there.
for a while i have been wanting to build a device like THIS and THIS, the problem is that i can't get my hands on the small negative ion generator from those pages.
is there a simple alternative i can build myself?
maybe i could even use a very weakly driven flyback?
Backyard Skunkworks
Wed May 20 2009, 02:30PM
Might wanna have a look here Link2
Solidacid
Wed May 20 2009, 04:37PM
i have been there already but the "mains powered" part seemed like a problem(but could probably be fixed by using 8 AAs) also, where would i get a "12 volt to 8 kilo volt autotransformer"? an ignition coil sounds like a bad(painfull) idea
RichM
Thu May 21 2009, 07:17PM
RichM Registered Member #950 Joined: Sat Aug 11 2007, 02:11PM
Try a voltage multiplier powered by a cold cathode tube PSU
DIY Voltage Multiplier
RickR
Thu May 28 2009, 04:29PM
RickR Registered Member #93 Joined: Thu Feb 09 2006, 04:11PM
Hopefully I'm not bringing this thread too far back from the dead, but there are two auctions on eBay that probably fit your needs:
260394946600
and
170326121628 (although the title refers to 7.5VDC, the description identifies the output as 7.5KVDC).
Edit:
My bad! I didn't check your location (thanks for including it, by the way). The shipping to Denmark would probably be prohibitive. I'll try to take this into account before responding in the future. - Rick
I found these by searching the words: high voltage power supply
Rick
